ESY FEED BACK
Ever since I upgraded to the Esy thing not work as before. When any swith is left on for an outside light it should light up my keypad telling me it was left on. Also othe light that are on a timer if the light is left on, it stsyd on as if the esy is not reading the status of the switch left on or turned on
It's possible that your Insteon mesh network is marginal, or that you have noise on your powerline that's interfering with the Insteon signals . How many dual band devices do you have in your system.
If everything was working prior to moving over to the eisy try doing a restore device on the insteon devices that aren't working properly.
