7 hours ago7 hr As you said in a previous message, I bought the LOCAL version of the plugin. However, my devices came with a free speaker hub which is not supported.Everything is working fine with the speaker hub.Should I get a local hub? Can I use both hubs?Will I see a huge difference with local? I assume it would be faster in addition to not working when the internet is down. I use my outdoor motion sensor to trigger alexa but through the EISY so if internet is down, Alexa would not be triggered anyways. So I dont see much advantage other than the cloud being slower. With that said its a matter of seconds before Alexa says someone is in your driveway.
6 hours ago6 hr You can easily have multiple hubs - You only need the local hub if you plan your system to operate without internet access (for mission critical operation). Not sure there is a big difference in speed I would say unless you need its benefits, I would not buy the localHub - if you think you have marginal coverage, you can always buy another "normal" hub
