Friday at 06:44 PM4 days Hi,KeyPadLinc secondary button (Master Off) set up as Non-Toggle[Off] (so it only sends off to any responders in a scene where it is the controller). Works perfectly.I noticed that when I click the button it flashes twice - I am guessing that this is just to let you know it did something.I created a program that turns the "Master Off" keypadlinc LED "On" when a user clicks any of the other switches that this "Master Off" controls - works perfectly.Here is what I have found that is weird (took me literally HOURS of trying to work this out due to the debugging I put in the program). I created another program that will turn this LED light off when the "Master Off" is clicked - but what I found is that unless I program a 5 second delay into the program just before the command to turn off the "Master Off" LED - the LED will stay lit....If I program a 5 second delay you can see the button doing its own "flashing" thing - then a couple of seconds later the LED will dim. If its anything less than 5 seconds - the LED will flash away - but will then stay lit....If the delay is less than the 5 secs - then the program is definitely triggered (I created some variables to debug and capture what the program was going) - its just that the LED "off" command seems to be sent before the "flashing" process concludes - and for some reason the LED stays on.Has anyone encountered this - and have any insights why this might be happening?I suppose I can live with the delay at the Master Off when I click it - it just is a little weird......Thoughts/pointers/ideas?Has anyone set up a Non-Toggle[Off] - "Master Off" like this (that becomes lit when any of its "children" are On and Off when not, and will also turn off when you push it)?
Friday at 09:06 PM4 days Solution If you do something that triggers a scene (whether it be a switch, from the controller, etc) you really need to wait a few seconds before sending anything else. The Insteon cleanup messages take time to get completed. Sending commands during this time also increases the risk of accidental "all on" events.
