Disabled Folders - Please explain
I was reading some of the IoX documentation and saw a comment about folders being "enabled or disabled". I had never looked into that before, and thought "that would be a good way to handle programs I no longer actively use but don't want to delete either." I figured I could drag a non-used program into a folder and mark the folder DISABLED.
I know I can disable the programs themselves, but a comment in the doco said that under certain circumstances the ISY may go ahead and run a program even though it is disabled. To me, this sounds in the least inconvenient, and potentially dangerous. I just want a way to stash code away and know that it will never run.
So I created a new folder. When I right-click the folder I see the options to Enable or Disable the folder. I select Disable. First problem noted: There is no change in the folder icon or any other obvious change to indicate the folder is either Enabled or Disabled. Huh.
Next I created two test programs inside the folder and leave them Enabled.
Then I right-clicked the folder and now the Enable/Disable options are GONE.
I right-click the folder and go to Status. I have to search the Path column for the new folder. I see the two new programs, and in the Enabled column both show ON.
I right-click both programs and disable them. Go back to the Status page and now the Enabled column shows a dash (not OFF as I would have expected).
Can anybody help me learn how folders are supposed to work, as far as enabling/disabling, and why they don't seem to work the way I would assume?
Jon
I have no disable option or enable option for any of my FOLDERS, only programs.
However folders can be disabled via conditions added to their "IF" section.
Eg: If X is not X
always evaluates as FALSE.
Folders can also be disabled by program lines. This can be a convenient way of turning off a complete function all inside a folder. However one big caveat is if a program is currently running inside the folder when you disable it, the running program will stop immediately and not conclude, possibly necessary steps to terminate the process.
Programmes inside a disabled folder can still be called as subroutines AFAIK. This needs to be confirmed because I avoid actively disabling folders due to being a very obscure practice and bad programming practice. I do use them for defunct programmes not in current usage.
I do have old programs for reference in folders marked disabled. They do not trigger unless you have a forgotten program that executes one of them but same for a disabled program. In effect all programs have an extra if to say if my folder is enabled and..,
Eg: If X is not X
always evaluates as true.
Help tell me I'm not seeing things... Create a folder but don't put anything in it. Then right-click the folder and see the Enable and Disable options. Then put a program (even an empty one) in the folder. Then see that the Enable and Disable goes away. Delete the program and they come back. Sounds to me like an "undocumented feature".
Eg: If X is not X
I'm getting conflicting information... Please create a folder but don't put anything in it. Then right-click the folder name and you should see the Enable and Disable options. Then put a program (even an empty one) in the folder. Now you'll see that the folder's Enable and Disable goes away. Delete the program and they come back. Sounds to me like an "undocumented feature".
I simple want to park "retired" programs in there and be sure the ISY won't run them. Ever.
I may have to just export them to my hard drive and delete them from Admin Console.
Sorry for the repeated post. The forum is doing something funny to me.
The way a folder is disabled is by placing an IF condition on it like if 1 = 2. You add the If just like you do when a program is selected but instead a folder is selected.
I've seen several mention putting IF time conditions to say the contained programs only execute say from Sunset to Sunrise but their individual If conditions are also applied.
  • 5 weeks later...
I have a folder called Away Random Lights. It has a condition based on a variable that I set with a keypad button. So when that button is on, the variable is set to 1 and all the programs in the folder are enabled. When I turn that button off, the variable goes to zero and all the programs are disabled. Makes it easy to set random lights as I go out the door and turn them back off when I come back in.
Away Random Lights - [ID 0023][Parent 0001]
Folder Conditions for 'Away Random Lights'
$State_Random is 1
AND, in direct response to your other question, it is true that if you create a new folder with nothing in it, the right click will show you options for enable and disabled, but when you add a program to the folder, those options disappear. I consider this a bug, frankly. I can't think of any reason an empty folder would be enabled or disabled. Folder status should always be set by the folder conditions.
Edited by Andy P
