insteon motion sensor
im down t omy last old styleinsteon motion sensor. I have them outdoor. Im loking for an outdoor one that is battery operated . And this sensor has to work with my eisy. Now I have no like work on any sensor outside . Any Idea from anyone that has a sensor that works all the time every time.
I've had good success with Yolink sensors. They are reasonably priced, reliable, battery life is great, and there's a super developer (@Panda88) with a well supported plugin for eisy. You need a hub to go with them, but their hubs are also reasonably priced. Last I checked, a single sensor was about ~$45 on Amazon, ~$55 if you also get a hub, and ~$81 for a hub plus two sensors.
Just a warning - they are kinda like that old potato chip commercial - bet you can't get by with just one [okay, so maybe the commercial was "bet you can't eat just one"]. I started with a couple but liked them so much I now have their motion sensors, leak sensors, vibration sensors, door sensors, temperature sensors, and even a few of their no-neutral switches in my environment. All integrated with eisy and Home Assistant.
YoLink sensors work well for me, as well. I agree with @dwengrovitz that the battery life is really good. But, you must be willing to put in the (little) extra effort for the node server and hub. Furthermore, unless you go with the higher-end hub, you will be cloud dependent.
thanks alot guys Now I have to decide. I see the z-wave usb is out of stock
well I been told that there is no longer a Zmatter usb and they are working on something else. So that leave me with yolink Only problen I can seem to get log on to to get the node. For some reason it state im not amn authorized user. Yet I use the same user name and password for my Eisy. I just stiopped working. Im wounder why i buy the eisy and just bail.
10 minutes ago, Techman said:
Take a look at the Zooz Zwave USB Stick
Zooz 800 Series Z-Wave Long Range USB Stick ZST39 LR - The Smartest House
I'm not sure if it's 100% compatible with the EISY, but you can open a support ticket to find out.
I know the 700 series stick is supported, and someone on the forum said that the 800 series also works.
they have yet to answer my ticket. Zmatter usb is over they will no longer have it.
well it look like yolink for me. I finely got to the node store. I will need you guys to help me with the node setup . I dont understand it
