Tuesday at 11:33 AM2 days My downstream programming broke and I found the reason is that the device names now have a 'F' after their name, like this - used to be yomotionsens and now it is yomotionsensF for some reason? <node flag="128" nodeDefId="yomotionsensF"> <address>n008_8b4c020013c921</address> <name>Motion Kitchen</name> <family instance="8">10</family> <hint>0.0.0.0</hint> <parent type="3">32793</parent> <type>0.0.0.0</type> <enabled>true</enabled> <deviceClass>0</deviceClass> <wattage>0</wattage> <dcPeriod>0</dcPeriod> <startDelay>0</startDelay> <endDelay>0</endDelay> <pnode>n008_8b4c020013c921</pnode> </node>Also true for <node flag="128" nodeDefId="yovibrasensF"> and <node flag="128" nodeDefId="yoleaksensF"> and <node flag="128" nodeDefId="yothsensF">But not for <node flag="128" nodeDefId="yodoorsens">It is not just in the admin console, it is also in the polyglot consoleNode Name 3AddressNodeDefPrimary NodeHintEnabledIs PrimaryDeleteFan HVAC 18b4c0100097447yovibrasensF8b4c01000974470x00000000truetrue
Tuesday at 08:51 PM2 days Solution Each node used to cover operation for both Celsius and Fahrenheit (selection by user at startup). However, there is a bug in the PG3x not supporting this correctly in some cases. Thus, I had to split each node that deals with temperature into two nodes (selected startup) - one operating in C and the other operating in F. I had to give them different names, thus the letter F added to the name for the F setting node (if user selected F as temp unit). Yolink operates internally in C, so it seemed most natural to change the F node's name - thus the added F to the name. The same is also the case for Liter vs Gallon in does measuring water volume (adding a G)
Wednesday at 11:35 AM1 day Author OK< thanks, I adjusted the code to strip off the F and everything is working again! Appreciate the response. Thanks, Andy
