Wednesday at 01:59 PM2 days I am finding hte red on black is very hard to see or read... are these programs disabled? hard to tell. Status? hard to tell. I have no idea what the red mark is by the icon in the front of the programs --> Temp Sensor Conv as an example. Also cant really read the Running in red. and why red when its running a true? Am wondering if different color schemes could be put on the options list? @Javi
Wednesday at 02:04 PM2 days Author I blew up the screen shot to be able to see what the icons are... still am not sure how to read them. First line: Green lines, I assume means idle true. But what does the green running guy mean? Second line: Large green running man I assumes running true, then why is the word "Running" in red? shouldn't it be green? then the Red circle with crossout I assume means disabled, again, what about the small running man in green? what does it mean?Third line: Red lines I assume means idle false, circle disabled, and again what is the small running green man mean? thanks...
Wednesday at 04:34 PM2 days Badges are mostly for mobile when the other columns are hidden. Will likely change the x and check to text in the future.For the badges (small icons) tooltip description on hover over, Bottom Running badge is run at startup, the top badge is disabled.Main icon Color: Green -> last evaluate true (then), Red -> last evaluated false (else). Main Icon image: document -> idle, Running -> Program is running then or else actions, based on green or red color)
Wednesday at 04:45 PM2 days Yes, the black background isn't pleasant. Having color settings would be nice.
Wednesday at 05:49 PM2 days Author 1 hour ago, Javi said:Running -> Program is running then or else actions, based on green or red color)if the main icon is showing green running then the word running to the right should be green as well to match that the Then is running. Red for else.
