August 19Aug 19 I hate asking questions that have been answered before. I have been searching 2 and half hours for documentation on how to upgrade from 5.9.1 to 6.0.0. and have found nothing. I would love to hit the "Upgrade Packages" button, but don't want to regret it later.
August 19Aug 19 Here's the last update that seemed to include the Polisy: https://forum.universal-devices.com/topic/46475-updated-software-available/There is another release out that I do not think will apply to the Polisy. Remember, if you run into issues you can open a support ticket with UD: https://www.universal-devices.com/my-tickets/
August 19Aug 19 You cannot update to versions other than the latest release. The automatic update from the System menu will also no longer work. You can do it manually by logging into your Polisy with ssh and then doing:sudo pkg upgrade udx isy eisyui pg3xThis method was suggested by Michel at UDI. I've successfully upgraded two Polisys this way. Remember the release announcement warning:If your FreeBSD OS is below 13.2p11 (check via https://eisy.local:8443/WEB/sysconfig.txt), do not attempt this upgrade; it will brick your system. Edited August 20Aug 20 by Guy Lavoie
