13 hours ago13 hr I am trying to duplicate a skill that is gone from alexa.I could ask for a temp and it would tell me.The temp is in EISY but any way to pass it to an alexa annoucement?I know how to pass it to a notification which is what I might do but would be nice to ask alexa.
12 hours ago12 hr I looked for a way of doing this a while back and making an announcement for each temperature was the only workaround I had found. I did ask the author of the Virtual plugin to see if he could add a virtual temperature device (for Alexa), but that doesn't look like it might happen.
12 hours ago12 hr Author 22 minutes ago, Guy Lavoie said:I looked for a way of doing this a while back and making an announcement for each temperature was the only workaround I had found. I did ask the author of the Virtual plugin to see if he could add a virtual temperature device (for Alexa), but that doesn't look like it might happen.how would you send the temperature to alexa as annoucement.I would have to send the node address of the temp
11 hours ago11 hr I'm not sure what it's called in Alexa. Maybe it's a routine. But I'd create an Alexa routine that would trigger on a variable being equal to each value. So if variable = 75 then say "the temperature is 75 degrees". One routine per temperature.
