September 6Sep 6 I've been using the eisy-ui pre-release for a couple of months and still have the Admin console.I'm now lost in the weeds. I tried to migrate to the new eisy-ui. In trying to open I get a notice that eisy-ui can't be found. Can anyone please walk me through all the steps to replace my Admin console with the new release of eisy-ui and if I need to and how to delete the pre-release if necessary? Note: running on the latest Apple OS Thanks
September 6Sep 6 open https://eisy.localYou'll have to do the browser security 'open anyway' routine if your browser complains.
September 6Sep 6 Well eisy-ui isn't yet a replacement for admin console, but it's a great time to learn it, as it becomes more complete. If it was working before but isn't now, you should try doing "upgrade packages " from admin console. If that doesn't work, you might need to open a ticket.
September 7Sep 7 Author Thanks. I'm up and running. I'm not sure if what I did this morning fixed it? In the transition sequence, I don't remember if I restarted or rebooted or if that madw a difference or not. Thinking about that, I manually turned off the Eisy computer itself and then turned it back on. When I tried to start the program, all was fine. I made a couole of adjustments to a program and created a new one to become familiar with the new interface and all seems fine.
September 8Sep 8 Author Hello again, HELP... for some odd reason, now when I try to login to http://eisy.local, I get the following message: This site can’t be reachedhttp://eisy.local/ is unreachable.ERR_ADDRESS_UNREACHABLE
September 8Sep 8 40 minutes ago, Bob Amott said:Hello again, HELP... for some odd reason, now when I try to login to http://eisy.local, I get the following message: This site can’t be reachedhttp://eisy.local/ is unreachable.ERR_ADDRESS_UNREACHABLEIf you can ping it or access it with admin console ok, then try it with the eisy's IP address, ex: like this:http://192.168.0.123
September 19Sep 19 Using the IP address, as Guy suggests, is the only way I can access eisy.ui since macOS (Sequoia and newer web browsers including Safari and Firefox) do not give an option to access a non-secure web address. But once logged in with eisy's IP address and later when logged out for inactivity, if you refresh the page to log in again, the appended characters in the URL that were added during browsing within eisy.ui may prevent login from working [something may have changed because now the appended characters are no longer causing login to fail]. In that case, remove the appended characters at the end of the URL leaving only eisy's IP address. Or use a password manager to login each time. By comparison, on Windows 10 the Edge browser permits access to a non-secure site by accepting the risk. Edited September 20Sep 20 by Spring Behavior in eisy.ui changed.
October 16Oct 16 See Q&A at the bottom of https://forum.universal-devices.com/topic/47042-eisy-ui-is-getting-there-heres-where-we-stand/
October 17Oct 17 In my home-network, I must use the IP-address of my eisy, every time.My DHCP-server maintains a reservation for my eisy, so it always appears at the same address.My home-network uses Ubiquiti Dream Machine Pro, with DNS-massaging (ie Ad- and geo-)blocking. For me, it is no big deal to use IP-address.
November 2Nov 2 I'm using Eisy in a very large commercial building, with a large IT department. It's not like my home with a modem and router. If I try using just the IP, I get the same message as previously mentioned, that it's unavailable. I can access it using the portal but not by direct IP address. What am I doing wrong? Thanks!
