9 hours ago9 hr I am reluctant to use the staging repository because 1) there is the warning not to do so unless UDI has instructed you to. 2) It is not clear to me that it is possible to downgrade to earlier versions. (I was unable to downgrade from Beta to the Production instances and even restoring from an old backup did not restore the production versions).
8 hours ago8 hr 24 minutes ago, stillwater said:I am reluctant to use the staging repository because1) there is the warning not to do so unless UDI has instructed you to.2) It is not clear to me that it is possible to downgrade to earlier versions. (I was unable to downgrade from Beta to the Production instances and even restoring from an old backup did not restore the production versions).Well, there seems to be enough survivors here saying that it works. Unless your application is very mission critical, I would be confident enough. Your call really. The release notes for that staging version do mention a fix to scheduled times.
8 hours ago8 hr I did see the staging repository with attached request from UDI"Please do not use the Staging repo unless requested by UDI Support."They said please, so I elected not to go there.I wouldn't want to create any additional problems for UDI or myself.I'm happy to wait unless someone from UDI tells me to go for it.Thank you all!
7 hours ago7 hr I can tell you in staging it is the latest and greatest, when they compile or migrate it seems the updates go straight there. I tested Sunset for Michel several times and he would tell me to upgrade to those versions. I can confirm that Sunset has been working well since mid last week, but it did take two or three updates for them to get the bug.
