September 13Sep 13 I recently upgraded from my ISY 994i PRO to the eISY. eISY is runner 6.0.2 been working for a few weeks now. Suddenly my programs started to not run properly. I rebooted the eISY and nothing changed. I am also not able to connect to the eISY thru the launcher, it sees it but will not take the password I had. I did the hold the power button till light is red then three quick pushes of thepower button to reset to the admin password login. That does not work. I cleared all the Java crap and still not able to login. I decided to do a total reset of the unit and held in the reset pin for 30 seconds. Still nothing, admin/admin does not work. Now I don't know if the reset even worked. I did check on this site before placing question here and saw where someone had a non working eISY because it was not registered. When I did the switch over from my ISY 994i I thought I saw something say eISY is registered and thats when it was working up till a few weeks later now. I hope I can get this working again because lots of lights on motion sensors are now not working. Actually nothing is working now.
September 13Sep 13 Can you see it's IP address on your router? If so, can you ping it? If you can ping it, try adding it to your IsY Finder by IP adress: click on Add and write the url like this, for example if it's IP address is 192.168.0.123https://192.168.0.123:8443/desc
September 13Sep 13 Author eISY shows on the finder and I can ping its IP. The problem is I can't login into the eISY with either the password I had set or the admin/admin. I followed the instructions for doing a password reset by power off and push power button quick three times and it should reset password login to admin/admin, that does not work.
September 13Sep 13 How about eisy-ui? Tried just pointing your browser to http://<ip address> ?Can you connect to it with ssh?
September 13Sep 13 11 minutes ago, dennisric said:eISY shows on the finder and I can ping its IP.When you're trying to log in does it say provide the portal credentials or the "name of eisy" credentials? It should say one or the other just under the User ID and Password spots. Be sure you're using the correct credentials. If you're just using the device that is automatically found you're probably needing to use the portal credentials. To use the local you'll need to manually add: https://eisy.local:8443/desc (or use the IP of the eisy in place of "eisy.local")When you log in with the port 8443 used it should say "Use your (device name) userid/password". That's where you'd use admin/admin. I don't think clicking the button resets the password anymore. But I forget when that was removed.
September 13Sep 13 Author I can get in thru the eISY-ui but can;t control anything. My PLM is connected and it was working fine until just a few days ago. I have always used the ixo finder to login into the eISY and before the ISY 994i never had a problem. Going in that way does ask to use portal useridpassword.
September 13Sep 13 If you can log into the eisy with ssh, try this:sudo rm /var/isy/FILES/CONF/0.UCF sudo service isy restart Then try logging in again with admin / admin
September 13Sep 13 If SSH doesn't resolve the issue then remove power from the PLM and the EISYWait about 15 seconds then plug in the PLM, wait about 15 seconds then plug in the EISY.Clear your java cache, be sure to check all boxes, then download the IoX Launcher from here: https://isy.universal-devices.com/start.jnlp
September 13Sep 13 Author Not able to get in with portal useridpassword because I don't know what to use for useridpassword. Anything I use from previous logins don't work
September 13Sep 13 7 minutes ago, dennisric said:Not able to get in with portal useridpassword because I don't know what to use for useridpassword. Anything I use from previous logins don't workHave you tried what I posted just a bit earlier, using ssh? If it connexts and asks you for a password, use "admin", same for the sudo commands if prompted. Edited September 13Sep 13 by Guy Lavoie
September 13Sep 13 3 hours ago, dennisric said:Not able to get in with portal useridpassword because I don't know what to use for useridpassword. Anything I use from previous logins don't workgo to my.isy.io and reset the password.
September 14Sep 14 Author This is what I get when in the eISY try to turn a light ON. I did the SSH idea and it's weird because user and password to get into the eISY was admin/admin. I am getting into the EISY with the IoX Launcher but have to use my portal login. I can not control anything and the error above is what I get trying to control an item. I went in thru the https://my.isy.io/ and I think I found the problem going in that way shows MAC 00:21:b9:00:ec:b4 which is not the MAC of the eISY. I think my problem is the new eISY is not registered with UDI. Boy I have just lost a lot of hours of my life with this. I may just go back to my ISY 944i.I don't know what happened trying to attach picture in word doc. I don't see how to delete
September 14Sep 14 Author I may have found my problem. I am able to login using XOI launcher using portal credentials. I can't control anything and non of my programs will run. I did a diagnostic of the PLM and it comes up /Not connected. Looks like PLM failure install back in 2019. I do have a brand new one but to do a restore of PLM I would have to put all my battery operated sensors into linking mode. I have about 12 all together and that is impossible because some are motion outside needing ladder. This will take me all day to acomplish. Is there an easy way to install a new PLM?ThnaksDennis
September 14Sep 14 No, there are no shortcuts when battery powered devices are involved. It would be great if Insteon made a PLM where you could edit it's device ID!
September 26Sep 26 Author Thank you to everyone who gave suggestions to my eISY issues. I had several things happening at same time that I did this switch over from the 994 ISY. I just replaced capacitors in 9 of my togglelinc's that were all installed in the same year and began to fail as I did my upgrade to eISY. It took many nights after work and help from Michel Kohanim to figure out a few things.Thanks againThis is a very helpful form.
