How do I add a device to a scene?
On the eisy-ui I'm trying to add a device to a scene that's far down the page. I see I can drag and drop the device on to a scene that's currently on the page I'm using and that that works as it should (I'm assuming)
But I cant seem to drag it down the page to a scene lower than the bottom of the screen.
I've tried having two instances of the eisy-ui open but that didn't work either.
I'm guessing I'm going about it wrong.
I tried to drag and drop a device on to a scene but the scene was below my available screen. I couldn't seen to drag it down to make the page scroll down to the scene. I could drop it on scenes visible on the page so I believe I'm doing it right.
I tried having two instances of Safari open to drag to another window but that didn't work.
How would I accomplish this?
Andrew
3 hours ago, Javi said:
This is changed in beta, to show a selection dialog instead.
I should just wait for an official release or do I update to beta?
If I update how would I access that?
I've refreshed and rebooted.
Right click and drag still don't work as you've said. How do I add devices to scenes?
This is what I see when I right click and select add to groupScreenshot 2026-09-29 at 12.21.34 PM.png
In eisy-ui 1.3.11-1 (current beta and staging) and IoX 6.1.2_8 (staging) on my EISY, if I right click on a node there is an options called "add to group" -- choose this and there is a menu called "scene selector" that allows me to choose a scene to add the node to.
