October 5Oct 5 Seeing an error when creating a Backup using eisy.local > System > Backup & Recovery. Only noticed this after doing the recent Beta update.loX 6.1.2_7UDX 5.0.0_4PG3X 3.4.25eisy Ul 1.3.9The backup completes but shows this error:What am I missing or doing wrong?
October 5Oct 5 30 minutes ago, wrj0 said:Seeing an error when creating a Backup using eisy.local > System > Backup & Recovery. Only noticed this after doing the recent Beta update.loX 6.1.2_7UDX 5.0.0_4PG3X 3.4.25eisy Ul 1.3.9The backup completes but shows this error:What am I missing or doing wrong?Not really an error, it goes away when you migrate the PG3 plugins to eisyui.
October 5Oct 5 Author Not sure migration is my problem; eisy migration from PG3 to PG3X was performed in 2023.
October 5Oct 5 Solution 6 hours ago, wrj0 said:Not sure migration is my problem; eisy migration from PG3 to PG3X was performed in 2023.There's another migration, PG3 to eisyui 2026.
October 6Oct 6 4 hours ago, stillwater said:presumably in this case the red x just means there was nothing to back up.It was noted a PG3 migration was performed so I presume something was migrated.Anyway if the plugins are migrated to Eisyui then data is backed up.
October 6Oct 6 Author Since the eisy.local page shows "Plugins (Beta)" I had not previously performed the migration from PG3X to eisy. Opening "Plugins beta" showed a tab "Migrate PG3 plugins." After performing that migration, Backup now shows a Green check next to Plugin Data Files.Thanks all for your feedback, comments and suggestions. What an amazing, helpful forum!
