October 7Oct 7 Have switched plugins from PG3 to eisy ui plugins beta. My version is 1.8.60 and when I try to upgrade to latest version in the eisy ui store, I get message below and upgrade fails.
October 7Oct 7 There are no errors in the Yolink log - Maybe try to reboot the system or reinstall the nodes - there are other nodes with errors as well
October 7Oct 7 Author OK.. Rebooted eisy and restarted the plugin. Still get the same error. Interestingly, all of the Yolink devices seem to be working fine. Should I delete the plugin and add back in plugins beta, or add back in PG3 , then migrate?
October 7Oct 7 I saw there just was a new release of the UI - maybe try that before anything else I would try to delete and reinstall - I believe they are really the same
October 9Oct 9 Author Solved. Turns out that the plugin did not like updating via portal, but did update on local network.
Thursday at 01:11 AM4 days I'm having a similar issue after my migration to eisy. I was only running 3 PG3x nodes, and two of them migrated no problem. I cannot get the yolink nodeserver to migrate or install new as a plug-in. I've attached my logs below. eisy-logs-2026-11-05T01-08-48.zip
Thursday at 02:34 AM4 days I upgraded the plugin to 1.8.66 and it's just going haywire, notifications every few seconds alternating between YoLink failed and connected. I had migrated it to eisy Plugins well before upgrading and everything was fine till I upgraded. I returned the plugin to PG3 and it's still happening. I tried restarting reinstalling, no help. YoLink_11-4-2026_92949_PM.zip
Thursday at 02:46 PM3 days I will add that mine local plugin quit working when I migrated to the EISY "Plugin" from PG3. I migrated back to PG3 and it is remains non-functional, with all node and controller fields blank. I have restarted the PG3 node server and rebooted the EISY. Still no luck.Update: I rebooted the PG3 node server again and it seems to be back online. Edited Thursday at 02:50 PM3 days by oberkc
Thursday at 04:50 PM3 days I had the same thing happenign yesterday - It looks to me like two version of the node was running - I rebooted and it went awayStill, I did find a bug relating to speakerhub, that I am trying to fix
Friday at 01:00 AM3 days Thanks everyone for the advice. Rebooting PG3 didn't work, but rebooting eisy did. In the process, though, my nodes got scattered out of the YoLink folder I created. @Panda88 Grateful for your work on this plugin
