October 12Oct 12 I am running this: I migrated my plugins to the new plugins page in eisy-ui.There APPEARS to be a disconnect from UDM for the Plugin section of the mobile app. I think since the plugins were moved to Plugins (Beta) the UDM doesn't know what that is. If I tap plugins on the UDM settings page, says it can't start the node server, and clears the nodes on one of my plugins in UDM. I resolved it by restarting the eisy-ui service from the eisy.local page, the resynchronizing the UDM.
October 12Oct 12 The Plugins section in UDM is limited to PG3x, does not support eisy-ui plugins. Plugins is an independent service in UD Mobile, the only tie into other features would be the the Notification Plugin, but event then this is from the Notifications Screens, not the Plugin screens, so not sure how it could clear other nodes. Are you sure the nodes existed before you opened Plugins?
October 12Oct 12 Author 26 minutes ago, Javi said:The Plugins section in UDM is limited to PG3x, does not support eisy-ui plugins. Plugins is an independent service in UD Mobile, the only tie into other features would be the the Notification Plugin, but event then this is from the Notifications Screens, not the Plugin screens, so not sure how it could clear other nodes. Are you sure the nodes existed before you opened Plugins?The plugin affected is my Acurite weather station. Yes, the nodes where there before in UDM as I had one of them on my favorites. Plus, I use the values in those nodes to control programs and have for sometime. The eisy-ui presentation of the nodes initially said "internal server error" until I restarted the eisy-ui service using the services tab. After that, resyncing the UDM restored the node values there.I should add that this started with a sync request on UDM that resulted in an error saying "Can't start node server" (paraphrasing). Checking now, I see the nodes on that tab that all show "stopped" (guessing that's the old PG3 handling). Edited October 12Oct 12 by JimTurner more info
