Friday at 02:15 PM2 days Hello,I just fully upgraded my firmware and tried to access the new eisy ui. I can get to it from the http and the https, but when I try to login using same credentials I use to login to the portal it gives error (Error Logging in to plugins service).Please advise what to do now.I can still access from my phone and from IoX launcher.
Friday at 04:22 PM2 days see https://forum.universal-devices.com/topic/47255-error-logging-into-eisy-ui/#comment-408299
Friday at 05:28 PM2 days Author Thanks Javi,it got in but gave this error: (Error: Api not found)it gave this for nodes and plug ins. So i can't see any of my devices.
Friday at 05:36 PM2 days Author Also under insteon, it keep on loading foreverZ wave, API not foundAm i missing something that needs to be installed?from what i see here everything is up to date
Friday at 06:06 PM2 days Before ssh try upgrade packages again + wait 10 min.If that does not work, ssh to eisy: ssh admin@ipaddress.Then a sinlge command (below), wait a few seconds then check if the page loads.sudo service isy restartsudo service eisy-ui restartsudo service udx restart
