Mobile requires sync every use
When simply opening MOBILE running a Favorite may not work until SYNCHRONIZE is run.
I've tried LEGACY SYNCHRONIZATION to no real avail.
Thoughts?
Sometimes it does not issue a command to a device until Sync
Edited by HL3
None of mine have a toggle command.
I have for example:
-Groups for lighting run by 6 & 8 button wall keypads 2334-2 and wireless remotes 2342-232 for example.
-IOLinc 2450 to open Garage door.
When these are triggered the only occasional issues are via MOBILE then rectified by Synchronization. This is a repeatable condition. When using hardwire or wireless insteon devices performance is perfect.
When using Mobile SOMETIMES, performance is either deminshed or non-working. Synchronization rectifies these issues immediately.
It has had this behavior since deploying the eisy years ago. I waited chalking it up to product evolution.
I have for example:
This is not normal behavior, and has never been. Synchronization is only needed after adding a new device from outside of the app, it takes to long to do every time the app opens.
Does eisy have the latest firmware, if not it is possibly a bug that was fixed in later firmware. Most likely cuase.
If this is sometimes, then there is something causing the issue during these times. It could be the connection settings, do you have local connection settings, if so delete them they are likely incorrect. Most likely cause after firmware.
If that does not fix the issue, the first thing to check is if the app has status of devices when the issue is encounterd, if it does not it is not connected or isy/eisy is not responding.
Latest firmware all around.
No local IP. 8080 for eisy.
Interesting that sync resovles the issue
Edited by HL3
I will follow your advice & post.
Thanks for your help!
