Tuesday at 01:27 PM1 day Hi, I found some ambient light sensors that work very well giving a reading of 0 to 400+ giving them a very good range. However the problem is that the analog output is reversed from what is expected. 0 is light and 400+ is dark. Just wondering if there might be a way of inverting that through the webcontrl8 itself. Still looking for a light sensor that outputs the expected range of 0 for dark and 400+ for light. I do have some passive light sensors but they don't have the amp to increase their range of sensitivity.Thanks for any advice.GaryIt looks like it can be done with PLC programming but I would not know how to do that. Edited Tuesday at 01:33 PM1 day by garybixler
Tuesday at 04:03 PM1 day Author Thanks Guy,I added this to the webcontrol8 PLC programing.START SUB 500 AIP2 VAR1 SKIP_OFF: END It does work but I don't think the light sensor is very linear. I can get 0 in full darkness and 498 in bright light as a value in the variable.Gary
Tuesday at 05:20 PM1 day The ideal method is by integration (averaging over time). 4 or 5 samples spread out over several minutes, then take an average. Then discard oldest sample and take new one, keep averaging.
