Daylight Savings Time
On 11/1/2026 at 9:48 PM, RDewit said:
No solution here, still showing -8 GMT and yes to daylight savings when selecting Vancouver, BC. Is there an EISY update that I missed?
Yeah, seeing that on my older Polisy after the update. Using the new UI, I can now at least separately change the city, longitude/latitude, and DST rule. However, the real issue is that there's no option to set DST always on; the DST only enables or disables the DST rule and if disabled then DST is always off. Using the new UI, however, I was able to change city from Vancouver (UTC-8) to Calgary (UTC-7) and then turn of the DST rule, and make sure the right longitude/latitude were set for Vancouver (after click save, I had to refresh browser to see the full effects of my changes). It's still a fudge but seems to be working so far. Wish the new UI would simply allow me to select city to get the coordinates and then separately set the UTC offset and set the DST rule on or off (or allow me to define my own DST rule like Asus router or some of my NTP digital clocks).
Edited by ErikN
