3 hours ago3 hr Hi. I am running into issues with Daylight Savings Time. British Columbia, Canada (and several other provinces) have moved to permanent Daylight Savings Time. Overnight eisy automatically turned off DST when it should not have. There doesn't seem to be an option in the Configuration screen to select Canada, Vancouver with no DST and the Daylight Savings check box on the Clock screen is greyed out so cannot change the auto DST option and in the location selection window the Daylight Savings Rule cannot be changed either.I have tried manually setting a custom time and location but there is a problem with the Timezone Offset (GMT) field such that, whenever I change it manually, the system sets it to GMT -25200, making it impossible.I have tried hard reboot but doesn't help. I am on version 6.0.4Any ideas?Thank youErikN Edited 3 hours ago3 hr by ErikN
2 hours ago2 hr Same issue here. Can't turn off DST, can't customize offset (shows as GMT -25200?!). Also tried selecting Arizona time zone (DST off and GMT-7), but could not customize the latitude and longitude to match my actual location in Vancouver, BC. he configuration again sets the offset to GMT -25.200. Hopefully a solution is available soon as I have numerous customer systems (as well as my own system) that have programs using time of day triggers.
2 hours ago2 hr 1 hour ago, ErikN said:Hi. I am running into issues with Daylight Savings Time. British Columbia, Canada (and several other provinces) have moved to permanent Daylight Savings Time. Overnight eisy automatically turned off DST when it should not have. Any ideas?Thank youErikNSame issue, Calgary Alberta, temporary fix was to set to Regina Sask. Edited 2 hours ago2 hr by mmb
1 hour ago1 hr On the staging repo eisy.ui (1.4.8), when I go to System/Configuration and click on the i at the upper right corner of the sunrise/sunset display graphic, under "Details" there is a box labelled "DST Rule" with a drop down menu that has "off" as one of the options. I haven't tested this.
50 minutes ago50 min 1 hour ago, mmb said:Same issue, Calgary Alberta, temporary fix was to set to Regina Sask.This will set the time to appear correctly, but if your latitude and east-west location in the corresponding time zone are not close to your current time zone placement your sunrise and sunset times will be inaccurate.1 hour ago, stillwater said:On the staging repo eisy.ui (1.4.8), when I go to System/Configuration and click on the i at the upper right corner of the sunrise/sunset display graphic, under "Details" there is a box labelled "DST Rule" with a drop down menu that has "off" as one of the options. I haven't tested this.Not sure where in the eisy.ui you are looking at. I have not used the new UI much yet and do not follow your navigation through the interface.
