Monday at 07:18 PM3 days I am wondering if others are experiencing anything like this. I am on the latest versions from the Staging Repo, so that may be related, but I assume many others are as well.All too often lately, I find some switch in the house no longer functions, then I realize everything is what I will call "hung". The last two time this has happened, a couple of days ago and then again just now, the first thing I do is download all log files so I can try to figure it out, but there is nothing that I can see. I previously had some instances that were causing "queue full" conditions. I worked on some program and plugin poll times, and that is not what is happening here.Then I reboot eisy.So are others experiencing anything like this? I will open a ticket if needed, of course.Thanks for any feedback.Rob
Monday at 07:21 PM3 days @RRalston ,What are the entries in the logs and error log right before it hangs? Do you have any nodes with pending operations?With kind regards,Michel
Monday at 07:32 PM2 days Author Hi @Michel Kohanim While I know it was this afternoon, I am not sure exactly what time this occurred, I simply noticed a switch in the laundry room did not work, then checked other things as well.What logs should I check to answer your question and what exactly is the term I should look for? If it is "pending", then no, that is not in any of the logs.Rob
Monday at 07:35 PM2 days @RRalston ,isy logs (from eisy-ui). Each time you reboot, you will see things get started. So, in isy event log, you need to check what was happening before you reboot. The same in isy error log.With kind regards,Michel
Monday at 07:42 PM2 days Author These are the logs I downloaded before the reboot. Is one of these the same as the eisy-ui log? Sorry I am not understanding.I looked back at the download page and I see the eisy-ui there and is selected by default, so I thought I had downloaded it, obviously not.
Monday at 07:44 PM2 days iox-error.log and iox-events.csvAlso, why not a ticket?With kind regards,Michel
Monday at 07:51 PM2 days Author I will open a ticket now and provide the logs. I just thought if others were seeing this, then I would be patient.
