Question to others - System Hangs Requiring Reboot
I am wondering if others are experiencing anything like this. I am on the latest versions from the Staging Repo, so that may be related, but I assume many others are as well.
All too often lately, I find some switch in the house no longer functions, then I realize everything is what I will call "hung". The last two time this has happened, a couple of days ago and then again just now, the first thing I do is download all log files so I can try to figure it out, but there is nothing that I can see. I previously had some instances that were causing "queue full" conditions. I worked on some program and plugin poll times, and that is not what is happening here.
Then I reboot eisy.
So are others experiencing anything like this? I will open a ticket if needed, of course.
Thanks for any feedback.
Rob
Hi @Michel Kohanim
While I know it was this afternoon, I am not sure exactly what time this occurred, I simply noticed a switch in the laundry room did not work, then checked other things as well.
What logs should I check to answer your question and what exactly is the term I should look for? If it is "pending", then no, that is not in any of the logs.
Rob
These are the logs I downloaded before the reboot. Is one of these the same as the eisy-ui log? Sorry I am not understanding.
I looked back at the download page and I see the eisy-ui there and is selected by default, so I thought I had downloaded it, obviously not.
