Motion sensors not firing programs
@Panda88
Updated plugin to 1.8.71 last evening and this morning noticed motion sensors weren’t firing programs. I can see their status change in Yolink app and in Eisy but programs aren’t running. Some door sensors work as expected but not all.
The motion sensors command setting were set to “On Only” before update but all changed to “ON/OFF” after. I’ve changed them back but still not working.
Reinstalled plugin, restarted plugin and Eisy, with no help
Log attached. TIA!
YoLink-log-2026-11-11T14-14-54.799Z.zip
Edited by drprm1
Is there a specific motion sensor that does not work - it seems to work according to the log
I have had to load program - change something reert it back and then save - after that programs started to work again
I am trying to understand what changed regarding the startup - it is supposed to be saved but an upgrade may reset the database - maybe I need to store in files as well
I’ve got a few ms not working correctly. I’m focusing on a couple I use for “entry motion” lighting. The ms fires and status updates in Eisy but program doesn’t run.IMG_8525.png
I have changed program and saved it with no change
I think I found the bug at startup - I was actually using files, but they got erased when installing new server now - it has a accompanying bug -(
If we see the sttes changing under nodes, it should trigger they program - the node is not involved in triggering the programs - try to same the program again - I had a similar issue with eISY before
Testing the node has become difficult for existing nodes with eISY - but I'll do my best to see if I can test it
Edited by Panda88
If it matters I was checking a different ms which was a controller in a scene that appeared to be reset as a responder. (I was changing so many things to try and get it to work that I may be mistaken about this)
1 minute ago, Panda88 said:
I think I fopund the bug at startup - I was actually using files, but they got erased when installing new server now - it has a accompanying bug -(
Confused as to what you’re asking me to try
Go to the program that is not firing - change some thing - save it - change it back - save it and try again
Done that a few times with no luck
have you tried eisy-ai and ask why the program in not firing at a time where is was supposed to fire -
Michel will provide you with a key to try it out
Changed the trigger in programs to status rather than control (this previously worked) and seems to be working. At least the program fires.
What changed?
Spoke too soon. Not working
Edited by drprm1
It should be fixed in the new release - DON got stuck because of missing files - I think the installer in eISY now erases everything - vs overwriting files
I am testing a new release but it will likely be a day or two
Thank you!
(This program turns the light on at night to keep me from breaking my neck on a couple of stairs. Probably my most important one. 😂)
