Tuesday at 06:24 PM4 days I have two plugins on my Polisy installed from the eisy ui plugin section (not pg3x). These are two that I created and installed them from the developer section of eisyui, (where you set purchase options). On my eisy, when I push an update to git hub and update the store version, the plugin then reports that an update is available. But on the Polisy there is no mention of an available update. I had to click on re-install which did then install the latest version. The Polisy is running the current up to date production version of all the packages. Basically, it looks like the Polisy with the currently up to date production packages isn't doing version checks on plugins.
Wednesday at 12:50 AM4 days I'm not certain, but I suspect that it's behaving similar to PG3x. PG3x only checks for updated plugins a few times a day, it doesn't get notified when a plugin has been updated.However, when you submit the plugin update, it will force a check so that that machine sees the updated almost immediately. Again, this is how PG3x works, it could be different for eisy-ui / eisy plugins.
Wednesday at 01:50 AM4 days I think @bmercier mentioned eisy-ui only updates once a day and I haven't seen a way to force a check like PG3x had...
Wednesday at 03:01 PM3 days @Jimbo.Automates The update is every 4 hours. But this is not the problem he is having.@apostolakisl There is a bug in the current eisy-ui version where the latest versions numbers are not pulled from the store. This is fixed in the latest staging version, and will be in production most likely today. With the new version, you will get the Update chip, and an update button.In the mean time, if you just hit Reinstall, it will actually update. Reinstall and update really is the same thing, it installs the latest version and keeps your settings.
