Sunday at 08:09 PM2 days I am in-process of weaning myself from the Admin Console, but I notice that the eisy-ui program has different ways of reading/writing some Insteon configurations. For example, I have an Insteon 2844-222 Motion Sensor. In Admin Console which is working fine to control a scene that turns my kitchen light on and off. If I click on the motion sensor node on the Main screen, and then click the 'Options' button. A window pops up which shows a bunch of parameters that I don't understand. I have left all of them in their factory set-up except one called Motion Timeout. I used the Admin Console to set the Motion Timeout to 3000-seconds . This makes the scene turn the kitchen light off 5-minutes after the last time the sensor sees motion. With the eisy-ui, I right click on the motion sensor node and one of the selections is 'Configuration'. Left clicking 'Configuration' opens a new page that includes a gear icon called "Options'. Clicking the Options selection gets me a pop-up window with seven Options:Timeout (0–127)LED Brightness (0–255)Dark Sense (0–255)SensingNo LEDOn OnlyNight ModeThe 'No LED' has a blue checkmarks next to it, but all of the other Option values are blank. I set the Motion Sensor into communicating mode and clicked the 'Query' button hoping that the parameters in the Motion Sensor would upload, but no luck. The system did seem to communicate, but no data filled in. So, how do I set the Timeout if I want to change it from 3000-seconds?I also have an older 2842-222 Motion Sensor. The Configuration Options has the same window pop-up, but it has Timeout, LED Brightness and Dark Sense values filled in. The Timeout value is 8. Do you know what the Unit-of-Measure is?Before you ask, below are the versions I have on my system.Thanks,-JoePackage Current Version Upgrade Toeisy-ui 1.4.8 1.4.8IoX 6.1.2_10 6.1.2_10UDX 5.1.0 5.1.0PG3x 3.4.28 3.4.28iox-matter service 1.3.24 1.3.24mosquitto 2.0.18 2.0.18mDNSResponder 2881.100.56.0.1 2881.100.56.0.1libwebsockets 4.3.3 4.3.3
Monday at 05:15 PM1 day Insteon Configuration options were improved/fixed in eisy-ui 1.4.13https://wiki.universal-devices.com/Eisy-ui#Insteon
Monday at 10:51 PM1 day Author In eisy-ui 1.4.8, when I click 'System' and get to the System Upgrade/Upgrade page, the version in the Upgrade To column for eisy-ui is listed as 1.4.8 for 'Production repo' and 'Beta repo'. I clicked 'Staging repo' and a scary window popped-up saying:Staging RepositoryPlease do not use the Staging repo unless requested by UDI Support.Despite the warning, I clicked the 'Use staging repo' button. The number1.4.13 then appeared in the Upgrade To column. I didn't click the 'Upgrade Packages' button because of the warning Should I go ahead and upgrade to the packages from the Staging repo?
Monday at 11:24 PM1 day No, unless UD specifically instructs you to. Stick with upgrading the Production Repo.
Monday at 11:57 PM1 day Author Well I guess that I won't be able to enjoy the Insteon, "Configuration options that were improved/fixed," as described by Javi.... Not good if the Java Admin Console is going to be abandoned in three weeks.
9 hours ago9 hr Drag and drop for file organization. I set up my Christmas lights programs today and my frustration level is maxed out.
55 minutes ago55 min Yes, the old multiple click and drag option for scenes not being available makes it very laborious to create groups in the new UI. I have had to redo my Hue lights 3 times now and each time takes 2 hours...vs 20 minutes. And Find / Replace is a critical feature for when updating an older device that quits. UDI is getting closer with each Staging repo release....
25 minutes ago25 min Also, the ability to select multiple devices and apply a common action to them. I have 34 plug in modules I use at the Holidays for window candles. Enabling and disabling them one at a time, each with at least three clicks in the confirmation boxes, is a chore. In AC, it was a click and a shift+click to select them all and a single enable/disable command. That would be a welcome addition to EISY-UI.Also, in settings, the ability to forgo confirmation boxes altogether if that is the user's preference.
