OS 14.5 Release Is Now Available
Hello everyone,
We're happy to announce the availability of OS 14.5, IoX 6.1.2_18, UDX 5.5.0, and eisy-ui 1.4.13 for eisy (only). This is a major release that upgrades your OS to 14.5 and brings significant enhancements — especially for eisy-ui and Z-Wave/Zigbee support.
Highlights
  • udx
    • Upgrade Python from 311 to 312
    • Better upgrade progress notifications/messages
    • Faster boot
    • Better support for Polisy
    • Full eisy-ai support
  • isy
    • Fix for Philips Hue clusters
    • Lat/long and time zone issues especially for those in Canada
    • Fixed majority of Z-Wave restore issues to 800 series
  • eisy-ui
    • Now at 99+% parity with the Admin Console
A Redesigned Upgrade Procedure
Starting with OS 14.4, the upgrade procedure has been redesigned from the ground up. Your unit now creates a clone and upgrades the clone first. If the upgrade succeeds, you will reboot into the clone. From eisy-ui | System | Boot Environment, you can choose which partition to boot from, and remove the one that's no longer in use.
⚠️ Warnings | Please Read Before Upgrading
  • If your FreeBSD OS is below 13.2p11 (check via https://eisy.local:8443/WEB/sysconfig.txt), do not attempt this upgrade; it will brick your system. Instead:
  • Do not attempt the upgrade if you are remote from your eisy/polisy and/or using ISY Portal
  • Do not attempt the upgrade over WiFi make sure you're connected to your router via Ethernet
  • This is a major OS upgrade. Please do not touch the unit until it comes back online or prompts you to reboot
  • If your eisy does not come back online within 2 hours, please submit a support ticket
Upgrade Procedure
eisy-ui
  1. Menu | System | Backup & Recover and backup everything. For Z-Wave, you need to back it up separately
  2. Menu | System, choose Production Repo, and then click on Upgrade Packages
Admin Console:
  1. Back up your Z-Wave network, if applicable (Z-Wave | Backup)
  2. Back up your IoX (File | Backup IoX)
  3. Back up your PG3
  4. Click Upgrade Packages in Admin Console | Configuration tab
Do not use SSH to perform the upgrade; this will brick your system.
Do not reboot till you are notified.
As always, thank you for being part of the community, and please reach out via a support ticket if you run into any issues.
