eisy.local vs IP address
Still getting use to new UI. Improving.
If I read the documenation correctly, I should be able to access the eisy device using either eisy.local vs actual IP address.
I am able to successfully use the actual IP address, but I get a series of error messages when trying eisy.local (server IP address could not be found).
Did I miss something again when setting up everything?
Both should work. I personally use the IP address because it skips any problem with local name resolution.
@j.rieff eisy.local works using mDNS, In some networks, it's possible that eisy.local will not work. Your router may have security settings that prevents this.
If you have different subnets, with your eisy in one subnet, and your computer in a different subnet, that may not work.
2 hours ago, tazman said:
@bmercier is there a reason why eisy does not seem to resolve the .local addresses?
Usually due to mDNS filtering of some sort.. Network config and equipt are factors.
One forum member had a corrupt DNS cache causing eisy.local issues, cleared using DNS tools in his Firefox browser. Same issue on my brother's Mac but cleared using Safari developer tools. Once cleared they were fine.
Edited by mmb
Or more simply, one forum member had a corrupt DNS cache on his Firefox browser that was causing eisy.local problems. Same issue on my brother's Mac using Safari. Once cleared they were fine.
I think you might not understand what I was asking, eisy.local works on my network and I use it for other network use but I can not use the .local witin the eisy box. Unfortunately I have to deal with a network that does not have the ability to reserve ip addresses.
One workaround could be to assign a fixed ip address to the eisy. It needs to be left as dhcp, but you can assign it an alias address that is fixed. You could also put it's own name in it's /etc/hosts file with it's ip address.
See here about setting an alias:
https://forum.universal-devices.com/topic/47335-eisy-connectivity-due-to-dhcp/#comment-408818
If you're trying to refer to the IP of the eisy itself, can't that done using localhost or 127.0.0.1?
What are you trying to do?
I would like to use the .local addresses in plugins but the eisy box itself can not resolve the .local. [admin@eisy ~]$ ping power.local
ping: cannot resolve power.local: Name does not resolve
[admin@eisy ~]$ ping eisy.local
ping: cannot resolve eisy.local: Name does not resolve
While other devices on the network can.
PS C:\Windows\system32> ping eisy.local
Pinging eisy.local [192.168.12.154] with 32 bytes of data:
@Guy Lavoie I read what you posted but I do not see the relevance to what I'm looking for. My network resolves the eisy.local so I don't see how adding a alias to it would help.
Well my understanding is that you want a host name that you can use within the eisy (like as a plugin parameter) to talk to the eisy itself, like localhost. I was thinking that you could assign a secondary, fixed IP address to your eisy (since you can't reserve a DHCP address), and then add an entry in it's /etc/hosts file to use as a host name internally. For example, if your eisy has an address like 192.168.0.123 and you'd like it to have a fixed address like 192.168.0.50 and a hostname like "bobby", then you'd add a line in the /etc/rc.conf file. The line is (for a eisy) :
ifconfig re0 192.168.0.50 netmask 255.255.0.0 alias
and in the /etc/hosts file you add a line:
192.168.0.50 bobby
Now your plugin parameter (or whatever you want) within the eisy could access the eisy with that IP address or name.
@Guy Lavoie no the plugins that need an IP address to contact items outside of eisy like magic home and some of my own that connect directly to th IP address give me problems when they get assigned a new address.
So it's those outside devices that would need to have a constant, predictable IP address that the eisy would then connect to. Sounds like the network has particular characteristics, especially if you cannot reserve DHCP addresses for devices. I imagine this isn't a typical home network. Adding a small router that could do that also doesn't seem to be an option.
I am just trying to use an 'easy" way of accessing my eisy on the home network. When I enter eisy.local into a Windows 11 browser (Edge, Chrome, ...) I receive an error message indicating the eisy.local's server IP address could not be found. When I enter the eisy physical address in the browsers I receive the my eisy logon page.
When I enter eisy.local into one of the browsers on my Mac everything appears to be working correctly expected.
Now, back to the Windows 11 PC. When I try to clear DNS via CMD Window via ipconfig /flushdns, I receive an error message indicating elevation is required. ???? Nothing happens when I clear the host DNS cache in Chrome
Just trying to implement based on the features in the documentation. I know using the phycial IP address will work.
After realizing I was not on the CMD Prompt as Admin, I fired up CMD Prompt as Admin. Same results. Oh well, .... Just use the IP address.
So you you performed ipconfig /flushdnsand it completed but eisy.local still does not work? That fixes my Windows computers when they have issues.
