sun-sense Posted October 21, 2010 Posted October 21, 2010 I have tried to setup the Remote Linc #2440 but it doesn't pick it up. Are there any version issues with this device. My device, in the battery compartment says... 4207 REV 1.0 Any ideas ?
Michel Kohanim Posted October 21, 2010 Posted October 21, 2010 Hello sun-sense, Are you trying Link Management | Add a RemoteLinc? If so, would you be kind enough to go to Event Viewer (Tools | Diagnostics | Event Viewer), change the level to 3, and then retry adding your RL. Once it fails, please copy/paste the output of the Event Viewer here. With kind regards,
sun-sense Posted October 21, 2010 Author Posted October 21, 2010 Hello sun-sense, Are you trying Link Management | Add a RemoteLinc? If so, would you be kind enough to go to Event Viewer (Tools | Diagnostics | Event Viewer), change the level to 3, and then retry adding your RL. Once it fails, please copy/paste the output of the Event Viewer here. With kind regards, "Are you trying Link Management | Add a RemoteLinc?" Yes. Forgot to add. I have 2x2442 SignalLinc Rf and 2x2443 Access Point devices installed in the house. The nearest 2443 is about 12 feet away. I have already installed in the ISY-99/IR pro... 8x2420M PIR's 3x2456D3 LampLinc 3x2456S3 ApplianceLinc 2x2450 IOLinc 2x2430 ControlLinc Event Log Wed 10/20/2010 09:54:49 PM : ---- Initializing the linked devices ---- Wed 10/20/2010 09:54:49 PM : ---- All Linked Devices are now initialized ---- Wed 10/20/2010 09:54:49 PM : ---- Add remaining devices ---- Wed 10/20/2010 09:54:49 PM : [ A 1E B9 1] Removing all links Wed 10/20/2010 09:55:11 PM : [A 1E B9 1 ] Failed getting engine version. Reverting to i1. Wed 10/20/2010 09:55:33 PM : [ A 1E B9 1] ** Not added ** Remove Device Links failed Wed 10/20/2010 09:55:33 PM : ---- All Remaining Device Added ---- Wed 10/20/2010 09:57:24 PM : ---- Initializing the linked devices ---- Wed 10/20/2010 09:57:24 PM : ---- All Linked Devices are now initialized ---- Wed 10/20/2010 09:57:24 PM : ---- Add remaining devices ---- Wed 10/20/2010 09:57:24 PM : [ A 1E B9 1] Removing all links Wed 10/20/2010 09:57:46 PM : [A 1E B9 1 ] Failed getting engine version. Reverting to i1. Wed 10/20/2010 09:58:08 PM : [ A 1E B9 1] ** Not added ** Remove Device Links failed Wed 10/20/2010 09:58:08 PM : ---- All Remaining Device Added ----
Michel Kohanim Posted October 21, 2010 Posted October 21, 2010 Hi sun-sense, Are you sure you are putting your RemoteLinc in programming mode AND that it's close to an Access Point? With kind regards, Michel
sun-sense Posted October 21, 2010 Author Posted October 21, 2010 Hi sun-sense, Are you sure you are putting your RemoteLinc in programming mode AND that it's close to an Access Point? With kind regards, Michel Well, I select Link management then remoteLinc The screen pops up. I hold the dim and bright buttons on the 2440 and several seconds later, the light on the 2440 flashes. I don't see any activity on the access modem though. Let em see if i can find another RemoteLinc. I'm sure I have one in a box somewhere. BRB
sun-sense Posted October 21, 2010 Author Posted October 21, 2010 .Well, I select Link management then remoteLinc The screen pops up. I hold the dim and bright buttons on the 2440 and several seconds later, the light on the 2440 flashes. I don't see any activity on the access modem though. Let em see if i can find another RemoteLinc. I'm sure I have one in a box somewhere. BRB OK - The other remote in the box worked. I tried the first one again - no joy. I will have to try to program it with a lamplinc the old fashioned insteon way and see if it works. If not, try for a RMA. Thanks.
