cannot link or add devices under 2.5 - FIXED
RichGer
Reverted back to 2.4 and can add devices again.
Linking
Most of the time was unable to link with 2.4,
never worked with 2.5.
I may have a noisy system - 60 devices, no filterlincs and several low voltage devices. Turned off low voltage devices where possible and still no linking. Switched controlled low voltage was switched off - no change in behavior under 2.5
RichGer,
2.5's driver is no different than 2.4 and I am quite confident the problems are noise related. I strongly advise going back to 2.5.
reverted back to 2.4 and can add devices again.
Most of the time was unable to link wit h 2.4, never works with 2.5.
I may have a noisy system - 60 devices, no filterlincs and several low voltage devices. Turned off lowvoltage devices where possible and still no linking. Switched controlled low voltage I switched off - no change n behavior inder 2.5
Will try adding devices under 2.5 again
BTW
remote "upgrading" back to 2.4 worked
Smile
Despite 10+ tries remote upgrade from 2.4 to 2.5 did not work
Was upgrade function within 2.5 improved?
Hi RichGer,
I just upgraded your system from 2.5 to 2.5 remotely. I 100% confident that you must've had some firewall issues since none of that function has been changed for at least 6 months.
BTW
Smile
      37k
      371.4k
