andrew67 Posted December 27, 2010 Share Posted December 27, 2010 I'd like to avoid dumping 100 insteon devices into my ELK M1 and programming it and the ISY at the same time... and would rather have the elk just trigger programs on the ISY... Any way to do this? My goals are to get the status of the motion sensors to trigger lights, and alarm conditions to trigger lights for safe exit. Thoughts? Link to comment Share on other sites More sharing options...
Michel Kohanim Posted December 28, 2010 Share Posted December 28, 2010 Hi andrew67, Unfortunately, the only way to do this is via sending X10 signal to ISY. Beyond that, ELK does not understand ISY programs. With kind regards, Michel Link to comment Share on other sites More sharing options...
andrew67 Posted December 28, 2010 Author Share Posted December 28, 2010 So I think this might be just fine, I just need to get some of the plumbing figured out... so: Does X10 mean the ELK needs to have some special purpose hardware to put X10 on to an actual power line, or does it refer to X10 commands over rs232 or perhaps encapsulated over the Ethernet? how would the ISY get access to the said X10 commands? through the Insteon PLM? ISY's second serial port? I get that the ELK has no concept of whats going on in the ISY. I'm counting on it. That way the lighting and the security can each worry about themselves with an enforced separation of what happens in the other box. Not as nice as the integration you have planned, but good enough for the next phase of what I need to do... Thanks! Link to comment Share on other sites More sharing options...
Michel Kohanim Posted December 28, 2010 Share Posted December 28, 2010 Hello andrew67, You have two choices: 1. ELK->PLM/PLC->Send X10 2. Use the A10/X10 module, import configuration to ELK, and then send On/Off commands to ISY from within ELK programs to those devices With kind regards, Michel Link to comment Share on other sites More sharing options...
apostolakisl Posted December 28, 2010 Share Posted December 28, 2010 Michel, What does ISY do with "x10" commands sent from Elk via IP. In other words, I have my Elk and ISY communicating via the M1XEP without a PLM connected to the Elk. If I add commands to the x10 slots on the Elk that don't have an exported/imported ISY target, does the ISY see these and can it respond to them. Lou Link to comment Share on other sites More sharing options...
Michel Kohanim Posted December 29, 2010 Share Posted December 29, 2010 Hi Lou, ISY hears the same X10 signals that it sends so you can have programs based on those X10 signals. With kind regards, Michel Link to comment Share on other sites More sharing options...
apostolakisl Posted December 29, 2010 Share Posted December 29, 2010 Michel, I would like to run some statements by you and you tell me if this is correct. So, let's say all of your "A" slots on Elk are filled with Insteon devices that were exported/imported to Elk and everything else is empty on Elk. When Elk says turn on "A1" it sends an IP communication and ISY maps that to the Insteon device and sends the Insteon command instead of an X10. Now lets say Elk says turn on "B1". It sends an IP command to ISY, but ISY hasn't mapped that to an Insteon device so it sends X10 "B1" command on? Furthermore, once it send "B1" on, it hears that same signal and a program could respond to it? Thanks, Lou Link to comment Share on other sites More sharing options...
Michel Kohanim Posted December 29, 2010 Share Posted December 29, 2010 Hi Lou, If ISY is connected to ELK, then all commands sent by ELK map to ISY node addresses one of which could be an X10 device. It's up to ISY to decide what to send on the wire. I have to do a little bit more experimentation with ISY hearing back the X10 sent. Today it does not work! With kind regards, Michel Link to comment Share on other sites More sharing options...
apostolakisl Posted December 29, 2010 Share Posted December 29, 2010 Curious, If you have an Elk XSP connected to a second PLM, and Elk sends a command like "A1 on", then will that command get sent as both an x10 via the xsp and to a node on ISY? And what happens if Elk sends something like "M1 on" and there is nothing on ISY mapped to M1, does it just ignore it? Link to comment Share on other sites More sharing options...
Michel Kohanim Posted December 29, 2010 Share Posted December 29, 2010 Hi Lou, Yes, ISY would get both: 1. If the address is mapped to an ISY node, then the action is taken for that node 2. The X10 signal is processed by Programs and if there are any conditions met, then they are executed If a command does not map to an ISY node, then ISY ignores it. With kind regards, Michel Link to comment Share on other sites More sharing options...
apostolakisl Posted December 29, 2010 Share Posted December 29, 2010 I already have an xsp but I don't have second plm. But as I understand then, if I got a second plm and used unmapped x10 addresses on the elk, then elk and isy could talk back and forth. So if m12 and m13 were empty spots I could write the following programs Elk Whenever light "m12" is turned on Then do something Whenver something Then turn on m12 ISY If X10 M13 turn on is received Then do something If something Then send x10 M13 on I suppose I could use flags to track status of conditions where Elk could turn a flag on and off in ISY by such programs based on some Elk condition. So the next question, is the Elk module actually going to happen sometime soon? Writing these programs and buying another plm would be pointless if the module were installed. Link to comment Share on other sites More sharing options...
Michel Kohanim Posted December 29, 2010 Share Posted December 29, 2010 Hi Lou, Yes, this should work. ELK is happening as we speak. I just can't give a definitive date ... With kind regards, Michel Link to comment Share on other sites More sharing options...
midrar Posted January 1, 2011 Share Posted January 1, 2011 Michel, Currently, the ELK does not support the Venstar thermostat unless you install a beta file using a XSP. Will your future ELK upgrade give the ability for the ELK to communicate with the Venstar stat? Link to comment Share on other sites More sharing options...
Michel Kohanim Posted January 2, 2011 Share Posted January 2, 2011 Hi midrar, Yes. With kind regards, Michel Link to comment Share on other sites More sharing options...
midrar Posted January 3, 2011 Share Posted January 3, 2011 What about in the ELk Java Console or Elk touch screen? Link to comment Share on other sites More sharing options...
Michel Kohanim Posted January 3, 2011 Share Posted January 3, 2011 Hi midrar, We do not have any control over ELK solutions. With kind regards, Michel Link to comment Share on other sites More sharing options...
