trying to restore network resources
I made some changes to my network resources and it wasn't working like I wanted so I went to restore from a backup of network resources I made before the changes.
Upon doing the restore, the system hangs. I have an hourglass and no ability to do anything. I can't log off or anything. I have to use task manager to exit it. When I go back to it, the network resources is empty. I tried adding new files manually and it works. But, the restore function once again hung it up. I tried rebooting the computer and the ISY, same result.
I know the backup is good because I had sent it to Michel to look it over and he was able to open it.
When I activate the restore, the items I had start to show up, not all of them, but at least a few. Some of the times I tried the restore most would show up, other times only a few, but regardless, it hangs after that.
What should I do?
Also now I see that doing a restore doesn't assign the network resources the same id so my programs have gotten scrambled. I think that is something that you might want to look at fixing in future firmware upgrades.
Hello apostolakisl,
Thanks so very much. I just tested this a few times and it works fine. Basically, this is what it should do:
1. Delete everything from network resources
2. Recreate them in the order they were in the table before the export
Did the Admin Console first remove all the other entries before doing a restore?
Michel,
Yes, first I ran restore, the system hung and after about an hour I task managed out of it and re-opened ISY. The network resource tab was empty at that point.
I tried again, same result. I tried from a different computer, same result. I tried a hard reboot of ISY, same result. The only difference was that sometimes it would load a variable amount of the contents of network resources before hanging. I have 90 items and it might load 6, or 36, but then would freeze up and never finish. At this point a task manager exit of ISY and re-open of ISY would still be blank at network resources tab.
I did try doing "import" on one of those tries to see if I could import that backup file, but that one failed the same as the others.
Finally I had success on about the 10th try. I don't know why it worked becuase I just kept doing the same thing each time (I like beating my head on the wall). I suppose it is possilbe that I hit "import" instead of "restore" on that last try but I am 99% sure that I didn't.
Michel,
I thought you might like to know the follwing:
I don't know what the ID numbers were to start with, but I do know that I had deleted some which my recollection tells me should have left empty ID's. After the restore, the id's are now contiguous.
The programs that referenced network resources all refrenced the wrong ones after the restore.
Lou
Yes, I am quite certain I had deleted at least a couple network resources prior to doing the backup from which I did the restore.
Keep in mind that the "restore" part was not a simple click "restore" and go.
