March 1, 201115 yr Bug Fixes and Enhancements in 3.1.17 Release Date - 01/19/2012 Known Issues - Sorting Network Resources breaks the Test Button Bug Fixes -Beep logs -1 -Changing lat/long/location didn't update the time settings in the Admin UI properly -Occasional null pointer exception in Program Details -Output 64 in ELK -Make Area combo box usable when getting a flood of messages due to the common areas ELK bug -Numbers instead of names for values were shown in programs for conditions containing mode/fan/hold values for ELK thermostats -Admin Console size/state is not saved/restored in MAC -ELK not activating in some cases when ELK module is not installed -ELK possible inconsistency if the export file is not saved -MobiLinc Connect issues Enhancements -Sorting network resources based on names in programs -Added number prefixes for debug levels -Removed Electricity/Main tab and Flex Your Power -Send user friendly From (last name/first name) in Notifications --994 Only --Support for Multiple ECM1240s --ECM1240s now show up as nodes in the tree Developers - Removed CPW - Added CC (current current), CV (current voltage), and PF (Power Factor) for energy monitors Developer Links ------------------------------------------------------------------------------ Bug Fixes and Enhancements in 3.1.15 Release Date - 12/19/2011 Known Issues - None Bug Fixes -Added Variable for Zone/Keypad temperature in variables for Notifications -60/-40 degress should not show for ELK Zone/Keypad Enhancements - Use 1 for default responder link data3 values Developers - Portal Integration changes and enhancements - /rest/nodes//query did not work WSDK Links - URL for Web Services: http://www.universal-devices.com/developers/wsdk/3.1.15 - Documentation: -- WSDK Framework Development Guide -- ELK Integration: WSDK Development Guide -- NEW: Portal Integration Development Guide -- Smart Grid/SEP Development Guide-- 994 Only -- Zigbee Brultech Deveopment Guide -- 994 Only - UD AJAX (Open Source): -- UD Ajax 3.1.15 ------------------------------------------------------------------------------ Bug Fixes and Enhancements in 3.1.14 Release Date - 12/12/2011 Known Issues - None Bug Fixes - Fixed notfication where you see DON instead of ON - Fixed ISY Link table with empty entries - Changed the host for Alltel Wireless for SMS/text - ELK: fixed temperature in F - ELK: fixed both keypad and zone temperature conditions were always returning false Enhancements - ISY AJAX support for ELK Developers -- NEW: Portal Integration Development Guide Portal Integration allows an external server to act as a proxy as well as a client for ISY. In this way, all ISY events are published to the portal and the portal can use the same Web Services and REST interface to proxy commands for other clients to ISY. At a minimum, a portal solution removes the necessity for port forwarding. Other use cases are Energy Monitoring and Command/Control portals. WSDK 1. ELK - Support for ELK thermostats - Documentation fix for Keypad commands - Added TriggerZone service - Fixed descriptions for display text on keypads - Fixed some incorrect REST definitions 2. Documentation /rest/security moved to WSDK Framework Development Guide Links - URL for Web Services: http://www.universal-devices.com/developers/wsdk/3.1.14 - Documentation: -- WSDK Framework Development Guide -- ELK Integration: WSDK Development Guide -- NEW: Portal Integration Development Guide -- Smart Grid/SEP Development Guide-- 994 Only -- Zigbee Brultech Deveopment Guide -- 994 Only - UD AJAX (Open Source): -- UD Ajax 3.1.14 ------------------------------------------------------------------------------ Bug Fixes and Enhancements in 3.1.13 Release Date - 11/23/2011 Known Issues - Notifications On has been changed to DON Bug Fixes - Request failed on initial Admin Console startup for units without ELK Module - Climate screen compact and scrollable - RemoteLinc2 removing from scene caused an error - ELK programs relation conditions/comparisons were not correct() - ELK export ID mapping problem - ELK not receiving lighting events from ISY - Added better RL2 node names - Fixed programs not detecting Elk Function Key presses properly Enhancements - Added Refresh Topology for ELK Module - Support for ELK Thermostats - Support for Zone/Keypad temperature sensors - Renamed "Security Code" to "Access Code" - Moved "Security System" Tab to top level (renamed to "Elk") - Show/Edit addresses of devices exported to Elk - Zone/Keypad panels now show temperature Developers WSDK - Support for ELK Thermostats - Changes to WSDL, schemas and documentation for ELK Links - URL for Web Services: http://www.universal-devices.com/developers/wsdk/3.1.13 - Documentation: -- WSDK Framework Development Guide -- ELK Integration: WSDK Development Guide -- Smart Grid/SEP Development Guide-- 994 Only -- Zigbee Brultech Deveopment Guide -- 994 Only - UD AJAX (Open Source): -- UD Ajax 3.1.13 ------------------------------------------------------------------------------ Bug Fixes and Enhancements in 3.1.12 Release Date - 11/16/2011 Known Issues - Request failed on initial Admin Console startup for units without ELK Module - Climate screen too small - RemoteLinc2 naming convention not accurate - RemoteLinc2 removing from scene causes an error - ELK programs relation conditions/comparisons were not correct() - ELK export ID mapping problem - ELK not receiving lighting events from ISY Bug Fixes - Database exception when one could not be opened - Default values for Thermostat link records to alleviate the issue with All On/All Off --- NOTE: Thermostat MUST be removed from ISY and then added back - SwitchLinc Relay and SwitchLinc Relay Timer were reported incorrectly - Notifications included partial xml - Device database corruption in extreme cases - KPL linkages off by one byte when in a scene Enhancements - ELK Integration Module - Add RemoteLinc2 to "Link Management" menu - Added UI build version and timestamp Developers UDAjax - No changes WSDK - 1_fam.xml: SwitchLinc Relay and SwitchLinc Relay Timer were reported incorrectly - Update to documentation - Added support for ELK Module Links - URL for Web Services: http://www.universal-devices.com/developers/wsdk/3.1.12 - Documentation: -- WSDK Framework Development Guide -- ELK Integration: WSDK Development Guide -- Smart Grid/SEP Development Guide-- 994 Only -- Zigbee Brultech Deveopment Guide -- 994 Only - UD AJAX (Open Source): -- UD Ajax 3.1.10 ------------------------------------------------------------------------------ Bug Fixes and Enhancements in 3.1.10 Release Date - 10/18/2011 Known Issues - Network resources do not work if WeatherBug module is not installed. If you are interested, you can install a fix which will change the release to 3.1.11 but the actual code base is still 3.1.10: http://www.universal-devices.com/update ... 3.1.11.zip Bug Fixes - Resolution to UPnP performance issues for MobiLinc - Node names cannot include / - Do not start SSDP on MAC - Subscription performance improvements - Link database improvements to fix the .REC corruption issues - DNS errors repeated more than once for each error in the error log - All Lights On/Off for Housecode A should not effect the ISY's X10 status for devices with other House codes (such as B, C, D, etc.) - We can now query V2 Thermostats for Fan Mode and Heat/Cool status - The first node for IOLinc was not being properly set as primary (no functional impact) - /rest/log mime type changed to text/plain Enhancements - Removed Open ADR from 99 build as it served no purpose - Support for RL2 Developers UDAjax - No changes WSDK - Update to 1_fam.xml for RL devices - Update to documentation Links - URL for Web Services: http://www.universal-devices.com/developers/wsdk/3.1.10 - Documentation: -- WSDK Framework Development Guide -- Smart Grid/SEP Development Guide-- 994 Only -- Zigbee Brultech Deveopment Guide -- 994 Only - UD AJAX (Open Source): -- UD Ajax 3.1.10 ------------------------------------------------------------------------------ Bug Fixes and Enhancements in 3.1.9 Known Issues - None IMPORTANT If you choose to downgrade from this release to 2.8.8 and below, YOU MUST UPDATE THE TIMEZONE again once downgraded. Bug Fixes - Logs could not be retrieved Enhancements - None Developers - Same as 3.1.7 UDAjax -Added updating of hash for bookmarking and browser history -Update links for opening nodes and pages in a new tab/window (using middle click or right click menu) -Fixed minor problems related to updating device status, some cases updating twice or some situations not at all -My Devices & Scenes, bottom back button didn't always work right -Going back from a folder to Devices and Scenes no longer results in re-drawing all nodes -Notes on bookmarking and browser history: -Please keep a lookout for any controls/commands that might add to history or change the hash that shouldn't. -When opening directly to a node (using bookmarks or in a new tab) the page will first load config and the node list. Important Changes to WSDK - Introduced element in . Family is used to describe a family of devices such as ZWave/UPB/RCS/ELK/Etc. - Device category/subcategories can now be retrieved from 1_fam.xml (1=INSTEON family) - Log information and objects are now defined in log.xsd and instances are loginfo.xml, insterr.xml, upberr.xml, smtperr.xml, netstat.xml - Updated documentation Links - URL for Web Services: http://www.universal-devices.com/developers/wsdk/3.1.7 - Documentation: -- WSDK Framework Development Guide -- Smart Grid/SEP Development Guide-- 994 Only -- Zigbee Brultech Deveopment Guide -- 994 Only - UD AJAX (Open Source): -- UD Ajax 3.1.7 ------------------------------------------------------------------------------ Bug Fixes and Enhancements in 3.1.8 Known Issues - Cannot retrieve log and error log IMPORTANT If you choose to downgrade from this release to 2.8.8 and below, YOU MUST UPDATE THE TIMEZONE again once downgraded. Bug Fixes - Fixed the batch/battery button not showing up - Fixed the issue where setting on level/ramp rate to 0 would not initially take effect - Fixed System hang issues when multiple DNS requests are not resolved - Fixed System hang issues when Admin Console is left on when computer goes to sleep - Possible fix for missing database records Enhancements - None Developers - Same as 3.1.7 UDAjax -Added updating of hash for bookmarking and browser history -Update links for opening nodes and pages in a new tab/window (using middle click or right click menu) -Fixed minor problems related to updating device status, some cases updating twice or some situations not at all -My Devices & Scenes, bottom back button didn't always work right -Going back from a folder to Devices and Scenes no longer results in re-drawing all nodes -Notes on bookmarking and browser history: -Please keep a lookout for any controls/commands that might add to history or change the hash that shouldn't. -When opening directly to a node (using bookmarks or in a new tab) the page will first load config and the node list. Important Changes to WSDK - Introduced element in . Family is used to describe a family of devices such as ZWave/UPB/RCS/ELK/Etc. - Device category/subcategories can now be retrieved from 1_fam.xml (1=INSTEON family) - Log information and objects are now defined in log.xsd and instances are loginfo.xml, insterr.xml, upberr.xml, smtperr.xml, netstat.xml - Updated documentation Links - URL for Web Services: http://www.universal-devices.com/developers/wsdk/3.1.7 - Documentation: -- WSDK Framework Development Guide -- Smart Grid/SEP Development Guide-- 994 Only -- Zigbee Brultech Deveopment Guide -- 994 Only - UD AJAX (Open Source): -- UD Ajax 3.1.7 ------------------------------------------------------------------------------ Bug Fixes and Enhancements in 3.1.7 Known Issues 1. For PRO series, the batch and battery buttons do not show up for a while on the Admin Console 2. In case of too many successive DNS errors, the unit may hang IMPORTANT If you choose to downgrade from this release to 2.8.8 and below, YOU MUST UPDATE THE TIMEZONE again once downgraded. Bug Fixes - Connection issues caused networking to restart and sometimes hang the unit - Brultech EPI was no longer reporting events - Changed 02x25 to 2484SWH8 - DOS Optimization - Spurious Duplicate messages caused multiple commands to the same device to fail (IMPORTANT) - Support for X10 Devices that are not querable (device has to be removed and readded using a non-queryable type) - Support for X10 control in programs - Backup corruption in 3.1.6 - Notifications through GoDaddy - WeatherBug Temperature rate is degrees/h - Delete key also worked on Network and My Lighting nodes Enhancements - No network connection is logged only once followed by Established when network is re-established - Support for 2475SDB (InlineLinc Switch Dual Band) - Added System data/time/version to ELk Export file - Support for 2476D (0x01/0x30) - Offloaded Network Resources from programs task to its own task Developers UDAjax -Added updating of hash for bookmarking and browser history -Update links for opening nodes and pages in a new tab/window (using middle click or right click menu) -Fixed minor problems related to updating device status, some cases updating twice or some situations not at all -My Devices & Scenes, bottom back button didn't always work right -Going back from a folder to Devices and Scenes no longer results in re-drawing all nodes -Notes on bookmarking and browser history: -Please keep a lookout for any controls/commands that might add to history or change the hash that shouldn't. -When opening directly to a node (using bookmarks or in a new tab) the page will first load config and the node list. Important Changes to WSDK - Introduced element in . Family is used to describe a family of devices such as ZWave/UPB/RCS/ELK/Etc. - Device category/subcategories can now be retrieved from 1_fam.xml (1=INSTEON family) - Log information and objects are now defined in log.xsd and instances are loginfo.xml, insterr.xml, upberr.xml, smtperr.xml, netstat.xml - Updated documentation Links - URL for Web Services: http://www.universal-devices.com/developers/wsdk/3.1.7 - Documentation: -- WSDK Framework Development Guide -- Smart Grid/SEP Development Guide-- 994 Only -- Zigbee Brultech Deveopment Guide -- 994 Only - UD AJAX (Open Source): -- UD Ajax 3.1.7 ------------------------------------------------------------------------------ Bug Fixes and Enhancements in 3.1.6 Known Issues Backups using 3.1.6 are corrupted. Please do ensure you keep older backups and also that you do NOT restore 3.1.6 backups on your ISYs. IMPORTANT If you choose to downgrade from this release to 2.8.8 and below, YOU MUST UPDATE THE TIMEZONE again once downgraded. Bug Fixes -In extreme cases, query node might update the status of a device with the wrong value -Can drag/drop My Lighting into a folder -i2 command support for Icon SwitchLinc -ELK RP causes system hang -Same IP Detected errors in case of DHCP reservation and router not responding Enhancements -Support for 2491T All in One thermostat -Network/SSL performance improvements -Notification/SMTP improvements Developers - URL for Web Services: http://www.universal-devices.com/developers/wsdk/3.1.6 - Documentation: -- WSDK Framework Development Guide -- Smart Grid/SEP Development Guide-- 994 Only -- Zigbee Brultech Deveopment Guide -- 994 Only - ISY AJAX (Open Source): -- ISY Ajax 3.1.6 ------------------------------------------------------------------------------ Bug Fixes and Enhancements in 3.1.5 Known Issues It seems that our performance improvements to the SSL library has caused ISY to be faster than before so timeouts greater than 1000 ms causes ISY to wait for a response from the server after it has posted the Body but the server closes the connection before the timeout. In short, now, the longer the timeout, the more errors you are going to get. So, please try 500, 750, 1000, and 1500. The most important test is to not get Server not responding (that's what the timeout should be used for). Once you have the timeout set, you can ignore Body timeout errors since the email has already been sent. You will be pleasantly surprised by the improved performance with shorter timeouts. IMPORTANT If you choose to downgrade from this release to 2.8.8 and below, YOU MUST UPDATE THE TIMEZONE again once downgraded. Bug Fixes - Event Viewer levels do not stick unless event viewer is restarted - IOLinc sensor can be added as a responder to a scene even though it's already a controller for another - Conditions containing consecutive close parentheses were not evaluated properly - Rain Today precision was still 1/10 instead of 1/100 for Metric system - Regression: Backlight for some SWL models - Irrigation Cycle complete not updated properly - Irrigation values not evaluated properly in programs Enhancements - Suport for 2048 bit HTTPS server processing (delay of up to 20 seconds at initial connection) IMPORTANT - If you are using Rain Today in your programs, please note that the precision has changed from 1/10 to 1/100 and thus your programs might not run properly - If you are using Irrigation Module's variable in programs, please edit them for accuracy and make sure to save the programs again - If you are using 2048 SSL, please note that the initial connection may take up to 20 seconds Orchestrator 994 Series - Zigbee Diagnostics Developers - URL for Web Services: http://www.universal-devices.com/developers/wsdk/3.1.5 - Documentation: -- WSDK Framework Development Guide -- Smart Grid/SEP Development Guide-- 994 Only -- Zigbee Brultech Deveopment Guide -- 994 Only - ISY AJAX (Open Source): -- ISY Ajax 3.1.5 ------------------------------------------------------------------------------ Bug Fixes and Enhancements in 3.1.4 IMPORTANT If you choose to downgrade from this release to 2.8.8 and below, YOU MUST UPDATE THE TIMEZONE again once downgraded. Bug Fixes - Evapotranspiration, RS calculation used max temp instead of max-min - IRLinc nodes are now in the overview - Changes in the color scheme - Restore PLM fails when A10/X10 module is enabled Enhancements - Rain Today precision to 1/100 IMPORTANT If you are using Rain Today in your programs, please note that the precision has changed from 1/10 to 1/100 and thus your programs might not run properly - Irrigation Module: Irrigation Requirement/Water Deficit Yesterday - Support for 2476S - Support for 2486SWH6 - KPL Relay Timer - Support for 2472D - Dual Band OutletLinc Dimmer - AJAX enhancements Orchestrator 994 Series - Zigbee node structure with Endpoints, clusters, and device/profile information - Can now configure a UDI Zigbee router from the Admin Console Developers - URL for Web Services: http://www.universal-devices.com/developers/wsdk/3.1.4 - Documentation: -- http://www.universal-devices.com/develo ... Manual.pdf (Main document) - ISY AJAX (Open Source): -- http://www.universal-devices.com/develo ... UDAjax.zip ------------------------------------------------------------------------------ Bug Fixes and Enhancements in 3.1.3 IMPORTANT If you choose to downgrade from this release to 2.8.8 and below, YOU MUST UPDATE THE TIMEZONE again once downgraded. Bug Fixes - IOLinc set options was timing out waiting for an extended response - SyncrhoLinc i2 linking issues - IRLinc TX buttons does not show in Overview - Child folder could be set as the parent of its own parent - In presence of A10/X10 module, Restore PLM failed (not finding a file) - Clicking to the left/right of the slider had no effect - WOL: Error message when MAC address entered is not formatted properly - Intermittent communications with WeatherBug might cause programs not to run (extremely rare) Enhancements - Tools | Diagnostics | System Status: Last Reboot Time - Support for 2487S - 422: Support for Evapotranspiration in WeatherBug module - Experimental AJAX Interface instead of the HTML interface (With many thanks to Nick Stein) Developers - ControLinc/RemoteLinc reported ON/OFF incorrectly in REST - HTTP return codes for REST are now more consistent more consistent - URL for Web Services: http://www.universal-devices.com/developers/wsdk/3.1.3 - Documentation: -- http://www.universal-devices.com/develo ... Manual.pdf (Main document) - ISY AJAX (Open Source): -- http://www.universal-devices.com/develo ... UDAjax.zip ------------------------------------------------------------------------------ Bug Fixes and Enhancements in 3.1.2 IMPORTANT If you choose to downgrade from this release to 2.8.8 and below, YOU MUST UPDATE THE TIMEZONE again once downgraded. Bug Fixes - WB Light is % and not %/h - i2: Backlight not adjustable - i2: IOLinc error updating relay Momentary hold time - i2: On Level/Ramp rate require air-gap - Cannot create new program using 'new program' button after sorting unsaved programs by date - Program enabled flag not set correctly sometimes when creating new programs - Duplicate entries in selection boxes for variables - Program conditions containing variables after a paranthesis not evaluated correctly Enhancements - An experimental UI called Orchestrator Dashboard: viewtopic.php?p=46901 Developers No Changes since 3.1.1: - Retrieve variable names - Documentation: http://www.universal-devices.com/develo ... Manual.pdf - WSDL: http://www.universal-devices.com/develo ... iws30.wsdl ------------------------------------------------------------------------------ Bug Fixes and Enhancements in 3.1.1 IMPORTANT If you choose to downgrade from this release to 2.8.8 and below, YOU MUST UPDATE THE TIMEZONE again once downgraded. Bug Fixes - iMeter negative values support for device and programs - Do not try writing to devices with errors - Detect F/C for thermostats - Resets writing icon when failing to write to an IRLinc TX - Program Search/Replace popup not updated when summary/details tab changes - Show variable init value when 0 Enhancements - Return defined variable values (REST and Admin Console) - Return variable definition via REST (for variable names) - Support Search/Replace for variables - Support for variables in notifications - Support for SynchroLinc options Developers - Retrieve variable names - Documentation: http://www.universal-devices.com/develo ... Manual.pdf - WSDL: http://www.universal-devices.com/develo ... iws30.wsdl ------------------------------------------------------------------------------ Bug Fixes and Enhancements in 3.1.0 Known Bugs None IMPORTANT If you choose to downgrade from this release to 2.8.8 and below, YOU MUST UPDATE THE TIMEZONE again once downgraded. Bug Fixes - HTML - Program Cool/Heat do not show set points - Reset button on thermostat view is now removed - Typo: Hummidity to Humidity Enhancements - Program variables viewtopic.php?t=5987 - 994 Integrated Zigbee module to communicate with Brultech meters Developers - Documentation: http://www.universal-devices.com/develo ... NSTEON.pdf - WSDL: http://www.universal-devices.com/wsdk/i ... di3.0.wsdl With kind regards, Michel
March 2, 201115 yr And I'm holidays this week, will have to wait a week to experience variables! * Orest
March 3, 201115 yr We had to postpone our 3.1.0 cycle to include some minor bug fixes. Currently, we plan to release 3.1.0 beta by 03/07/2011. My first post as a new ISY-99 user, thanks for making a great product better! I'm just curious about numbering of releases...the latest publically available firmware I see is 2.8.x, and now there's a 3.1.0 beta in the works? Did you skip 3.0 or did I just miss it? (If the latter, just thwap me with a cluestick.) Bruce.
March 4, 201115 yr Author Hi Bruce, Welcome! Releases numbers are based on the extent of changes in the release. So, if we have a major release, the major number changes (i.e. 2.x.x to 3.x.x). The second number is the release number. We do have 3.0.x internally but since we added major changes to address our features on our other lines, we chose 3.1.x so that all products are in synch. With kind regards, Michel
March 5, 201115 yr Man, that will teach me not to check back here in a two-week period. I can't believe we are getting variables! I can't wait to see how they mature over time, but they will definitely simplify some of my programs as they stand right now.
March 5, 201115 yr I am also excited to see variables. I had an Ocelot for about 3 years before making the move to the ISY. There were so many features that made the ISY so much better, but my one frustration was the lack of variables. However, even without variables, the ISY is by far the very best home automation product that I have ever owned. The support and free ongoing software updates are fantastic!
March 26, 201115 yr "Detect F/C for thermostats" Hmm! What does this mean? Does it mean we can trigger on the fan turning on and off when heat and cool are triggered?
March 27, 201115 yr Author Hi andyf0, Sorry for not being clear enough. F=Fahrenheit and C=Celsius. With kind regards, Michel
March 31, 201115 yr from the web interface when I change the temperature from 70 to 71 it doesn't update the temp on the web interface. 2441v Insteon Adapter in a Venstar T1800
March 31, 201115 yr Author Hi polexian, Loops are quite interesting! Of course a limited one can be use using Repeat. By web interface do you mean HTML interface? With kind regards, Michel
March 31, 201115 yr Now that we have variables.... how about some do whiles and while? We may add that at some point, but you do have most of that functionality now by having a program do a 'Run If' on itself, essentially using the conditions in the 'If' as the 'while' condition. Pgm: 'Bathroom Timer' If $BathRoomLightCount > 0 Then Wait 5 minutes $BathRoomLightCount -= 1 Run Program 'Bathroom Timer' (If) Else - No Actions - (To add one, press 'Action')
March 31, 201115 yr Wouldn't that take up more memory than a do while since it's nested? It would take about the same amount of memory. The point of the post really was that you can do this now, although more direct support for 'while' may be added in the future.
April 6, 201114 yr Author Hello all, Release 3.1.2 (Beta) is now available at: http://forum.universal-devices.com/viewtopic.php?t=6194 With kind regards, Michel
May 17, 201114 yr I see 3.1.3 is posted. But there's no link for it. I pulled it by changing the 3.1.2 link to 3.1.3. I'm afraid that may not end up being the real 3.1.3 though.
May 17, 201114 yr Author Hello Andy, Not out yet ... we are hoping to have it out by the end of the week or beginning of next week. Currently testing and adding more features. With kind regards, Michel
May 22, 201114 yr I upgraded from 3.1.2 to 3.1.3, when I click on Administrative page, I receive Java error: Applet com.universaldevices.client.ui.UDClientApplet notinited, resulting in the admin page failing to load. I tried the basic Java that ISY recommends on a 'clean' machine - JRE 6U5, as well as the current version - both product the same error. How do I roll back to 3.1.2 when I cannot log into the admin console?
May 22, 201114 yr Author Hello phenneberry, 3.1.3 is not released yet ... how did you upgrade to it? Please do not try downgrading. Simply point your browser to http://www.universal-devices.com/99i/3.1.2/admin.jnlp . With kind regards, Michel
May 22, 201114 yr Michel, Are you a .x behind? From the first post in this thread ... Bug Fixes and Enhancements in 3.1.3 IMPORTANT If you choose to downgrade from this release to 2.8.8 and below, YOU MUST UPDATE THE TIMEZONE again once downgraded. Bug Fixes - IOLinc set options was timing out waiting for an extended response - SyncrhoLinc i2 linking issues ... That post was last edited by you a couple of weeks ago ... "Last edited by Michel Kohanim on Thu May 12, 2011 7:26 pm; edited 7 times in total" * Orest
May 22, 201114 yr Author Hi Orest, This is not a release notification but about what you should expect in 3.1.3. We are waiting for a few more enhancements before we release 3.1.3. With kind regards, Michel
