Configure Delay, and other console defaults
The Configure Delay command in the Telnet console is undocumented in both the Wiki and the PDF manual. (As well, this documentation is out of date in that it includes settings that are no longer supported.) As well, the console doesn't show what the default is. (It does for some commands, but not for CD and some others.) So, if you've changed the delay, you'd have no idea what to set it back to to go back to default.
What is the default value?
Can the software be updated at some point to show the default value? Can somebody get the Wiki and PDF updated?
Hello jtara92101,
They are not included for a reason!!! You should not touch these parameters or otherwise you might have intermittent communications with the PLM.
Don't you think, though, that you should at least document the fact that they shouldn't be touched?! Maybe just something like "don't change this parameter unless you have been instructed-to by tech support?"
Could you please answer my question, and tell me what the default value is for Delay? I think I may have altered this in the past, but since I don't know the default value, I have no way to know if I have changed it or what the default value is that I should change it back to if I have changed it.
I was having a great deal of communication problems, and I may have changed this in desperation. I moved an RF link, and that seems to have largely solved the problems, and now I want to set all the parameters back to defaults. I changed retries back to the default of 2, but I need to make sure everything else is back to default values.
