Why is the clock on the gui not the same as ISY's?
I have noticed when writing programs and testing them that the time shown clicking away in the corner of the gui is different than ISY's internal clock.
For example, this morning, I was testing a program. It was set to trigger at 8:49. By the gui clock 8:49 came and went, then at 8:50:30 (by the gui clock) the program ran. The "last run time" on the gui showed 8:49:00 after that.
Michel,
I am not sure I understand you. What do you mean by "does it's one incrementing"?
Are you saying that the gui runs its own clock and then every 5 minutes synchs with the ISY?
Does it seem right to you that the gui would have been almost 2 minutes different?
Lou
I was following the program summary page looking for run times and true/false changes. I was looking at the clock that was running in the upper left corner of the gui. The connection is good I assume, since the program summary did change true/false and did update the run times as I watched.
Can't say. I don't remember if it was already up or if I just opened it up right before I started working. It could have been up for more than 24 hours. I suppose you are suspecting that it was up for a long time and the clocks were running at different speeds, but how does that fit into the "sync every 5 minutes" concept.
