handyman300 Posted December 18, 2011 Posted December 18, 2011 Any chance at getting the Bayweb Thermostat integrated into the Isy99i ? I have the Isy99i and the Bayweb installed in 3 houses together. I really like the Bayweb because you can set the parameters online and it has a motion detector that allows you a 3rd level of temperature control. Integration would be simply to allow the following: Change the profile Change the activity Change the temperature set point Change the mode Bayweb supports api integration. www.bayweb.com Thanks for considering this.
Michel Kohanim Posted December 19, 2011 Posted December 19, 2011 Hi Mike, Unfortunately not ... I am sorry. With kind regards, Michel
az1324 Posted December 20, 2011 Posted December 20, 2011 You should already be able to do this through the network module. You just won't be able to get any 2-way feedback.
