Blackberry security issue --- Help!
Got a new software push today on my Blackberry Bold and now I can't use the web browser to access my isy-99i.
I get the following message:
"Unable to connect using the current security settings. Please contact your service provider".
Before this I had no difficulty accessing my isy-99i with my Blackberry. Anyone run in to this before?
Thanks Michel. I signed up for an account at cacert.org, but am trying to understand what they mean when they ask for:
"Paste your CSR(Certificate Signing Request) below..."
Not exactly sure what they want pasted into the blank form.
Unfortunately the Blackberry does not give any more info, just the message I mentioned earlier.
Hi ChrisNYC,
I am so very sorry for not giving you the details:
1. Go to https://www.universal-devices.com/ssl/insteon
2. Click on SSL Certificate Management | Create Certificate Request to CA
3. You will see a dialog with some numbers ... this is what you want to put in CACert utility (copy/paste)
4. Once you receive your certificate, then go to SSL Certificate Management | Receive Certificate from CA and Install (copy/paste again)
Hi Michel,
I got it now, except I only see options for a 512 0r 1024 certificate. How do I request one for 2048?
Hi Michel,
I tried installing a 1024 certificate and it looks like that did the trick, I can access the isy-99i from my Blackberry Bold again. Thanks for your help.
Chris
