"Vacation" Program
I want to set a program that anytime my Elk is armed in away mode, and the time is between sunset and 11:30, a light randomly turns on. Here is the program that I wrote:
From Sunset
To 11:30:00PM (same day)
And Elk Area 'Alarm' 'Armed State' is Armed Away
Set Scene 'Lights' On
Wait 20 minutes
Wait 45 minutes (Random)
Set Scene 'Lights' Off
The problem is that if we are home all day and have the lights on, once sunset hits, the ISY sees that the Alarm state is disarmed and initiates the else. For some reason I have having troube thinking through the logic. If I remove the else statement altogether, and we go out of town for a couple days, and that 11:30 hits, and the lights are still on. Would they turn off after the wait period even though the program conditions are no longer true? Or would they stay in their current state once 11:30 hits?
No. They would stay in their current status.
I am not sure that I fully understand your requirements, but what about removing the else path, then creating a second program:
if
time is 1130
then
set scene "lights" off
else
probably would want your second program to also have
"and elk is armed away"
as a provision, unless you want it to shut the lights off at 1130 even when you are home.
Thanks. I think that will do it. Pretty obvious answer I guess I was just over complicating it in my head
