Set variables to temperature, wattage, etc.?
I'd like to setup my isy-99i to email me the wattage of a device using imeter, or temperature from thermostat.
Is there a way to use a program etc. to set a variable to the readout of a device so I can send an email using it?
The only way I can think of is to make 500 programs for each wattage, and 40 or so for each degree... i.e. if temp = 71, set variable = 71, if temp = 70 set variable = 70... seems overkill..
  • 1 year later...
Michael, Where is the use of ${alert.action} documented?
Looked in the wiki, no luck. I am currently using it but interested in what other options there are.
John
Well I had to see it somewhere? I use that and alert.control
I know I saw them somewhere.....what other ones are there?
Regards,
John
