Basic Motion Sensor program
I'm programming challenged and am trying to set up a simple program to control a light with a motion sensor. I want the program to only execute at night and only if the light switch has not been manually turned on. In other words I want it to behave like a typical nighttime motion sensor operating only when motion is sensed after dark, otherwise the light can be manually turned on and off using the switch and unaffected by the motion sensor.
I tried coping the program that was on the forum but for some reason it's not working for me. Here is the list of programs I've been using...
'DrivewayMotion'
Control 'Driveway Motion Sensor-Sensor' is switched On
And Status 'Driveway Motion Sensor-Dusk/D' is On
And Status 'Driveway Spot' is not On
And Program 'DrivewayMotionTimerEnable' is True
Set 'Driveway Spot' 2 (Beep Duration)
Set 'Driveway Spot' On
'DrivewayMotionNotDetected'
Status 'Driveway Motion Sensor-Sensor' is Off
And Status 'Driveway Spot' is On
Wait 10 seconds
Set 'Driveway Spot' Off
Set Program 'DrivewayMotionTimerEnable' To Run At Startup
Set Program 'DrivewayMotionTimerEnable' To Not Run At Startup
'DrivewayMotionTru/False'
Control 'Driveway Spot' is switched On
And Control 'Driveway Spot' is not switched Off
Run Program 'DrivewayMotionTimerEnable' (Else Path)
Run Program 'DrivewayMotionTimerEnable' (Then Path)
Can someone tell me what I'm doing wrong? I have the sensor set up with the jumper on pin 5 so it will only be controlled from the ISY and I don't have it in a scene with the switch or manually linked to the motion sensor through the set button.
Can you expand on what is not working. Things like Beep Duration do not work as no device honors that setting (so far). But is Beep Duration a concern. That is why more detail regarding what is actually happening versus what you want to happen will be helpful.
Include what Motion Sensor options have been established.
Sorry, beep duration not an issue. The motion sensor will turn the light on when it first senses motion but will not turn it off after no motion is sensed. Also, it was turning the light off after I used the switch to turn the light on and then tripped the motion sensor.
What did you change between the motion sensor turning the lights Off and the motion sensor not turning the lights Off?
What motion sensor options are set?
I believe I have it set for both on and off commands and night only mode.
As for the change in the program, it originally said status not control in the first line of PatioMotion
The Program that turns the light Off has a Wait which means if any of the conditions in the If change during the Wait the Set 'Driveway Spot' Off will not execute.
Suggest looking at the Programs | Summary tab to see if the Program is triggered when the motion sensor sends the Off command. If not the other conditions in the If are preventing the Then clause from running. If it is triggered then look for when the Program 'DrivewayMotionTimerEnable' turns False. If that happens in the 10 second window the spot light will not be turned Off. I guess before any of that be sure the motion sensor –Sensor node is changing to Off. The motion sensor may not be configured to send Off commands.
Wait 10 seconds
Originally the wait was 2 minutes but I changed it to 10 secs so I could test the program faster. The program operated the same way regardless of the wait time.
I changed the program to:
Status 'Patio Motion Sensor-Sensor' is On
And Status 'Patio Motion Sensor-Dusk/Dawn' is On
And Status 'MasterBedRm Patio Spots' is not On
Or Status 'Kitchen Patio Spots' is not On
And Program 'PatioMotionTimerEnable' is True
Set 'Kitchen Patio Spots' 2 (Beep Duration)
Set Scene 'Patio Spots' On
This seems to have solved my problem although I'm not exactly sure why but I won't complain. Thanks for your help.
