Scene events
I started playing with the iOS remote application Roomie since it has an ISY plugin and I've been looking for something fast for a few specific events (I usually use Mobilinc but it's not 'fast')
Anyhow, Roomie has the capability to send commands to scenes (scene on, off, fast on, fast off, etc). However is there any way in an ISY program to see this events? My list includes just items so unclear how to trigger a program on say a scene fast on. If this isn't supported today, is it something that is likely to be added? It seems it would be very convenient to send a scene a command versus a specific device (so if the scene membership changes the programming stays the same)
Bill
Hi Michael,
Today they can not do programs but I did suggest it to them.
Best,
Bill
P.s. if technically possible please add a +1 to scene control events in programs
Michael,
I realize there is an issue with scene state, but not with scene control. If I send a scene a faston then the scene gets a fast on. That detection is what I'm asking for, does that help? The second part, what state is the scene in agree doesn't make sense since each members state can change after the control command.
Best,
Bill
Yes just the scene triggered by ISY would be useful. That said, I clearly don't understand part of the system. I thought the PLM was a scene member for every scene so I'm surprised you said you don't see the event when triggered by physical control of a scene member.
Thanks for the consideration, it would certainly be nice to not be coding in device ID's (which can change if a device fails) into Roomie and rather use scenes who's id's are basically static once created.
bsobel
The pressing of a button/paddle is seen by the PLM as that specific action.
If Control ‘kplbuttonC’ is switched On
Or
If Status ‘kplbuttonC’ is On
would be the Program statements to detect the event.
The button/paddle has a Scene/Group number different from that used by the PLM for control of the ISY Scene. Every time the discussion comes up about Scene Status there is never a consensus of what that means. However, your requirement looks at from the opposite side. Something like
If Control 'scenexxxx' is switched On/Off
addresses the requirement without getting into the discussion of what Scene "Status" should be. With the advent of more applications using REST this type of statement becomes useful.
