Electricity
What does the electricity tap under configurations do? Does anyone have a tutorial on how to set it up and what the different tabs under the electricity tab means?
Hello jmed999,
It all depends on what product you have and what modules are installed.
At a high level, you can configure ISY to communicate with Brultech Energy Monitors as well as our soon to be released energy monitor. If you have a Zigbee version, the communications will be over Zigbee.
If your utility allows you to communicate with your Smart Grid meter, and if you have 994i ZS then you can see consumption data from your utility meter.
I'm very interested in an energy monitor. How can I keep informed about your upcoming product?
Bob
Is there an upgrade program for the 99i to the 994?
Hi ekuzmack,
Yes, there is. Please do be kind enough to check our store front.
