August 6, 201213 yr I went to log on to my ISY and I am receiving the following message boxes. Needless to say - I can't log into my ISY.
August 6, 201213 yr Author Follow up to my Posting. I actually did a shutdown of my ISY to no avail. I have a message that I send automatically when I do a restart, so I knew that my ISY was apparently workin. I verified the status of my ISY using Mobilinc, so I was sure that it was OK. That was weird. The problem seems to have been some kind of corruption of the Java on my computer. I deleted the Java and still had Java problems I then restarted my computer and now everything is fine. FYI for anyone who may experience a similar event.
August 6, 201213 yr Hi Clarence, That does not make sense. When you rebooted ISY, did you notice the pattern of lights on the front of the unit? With kind regards, Michel
August 6, 201213 yr Author Hi Michel, In my previous post, I mentioned that everything came back just fine. My ISY was OK, I apparently had a problem with my Java somehow getting corrupted. I removed my Java Files and had to reboot my computer and all is fine. I did verify that ISY was OK with Mobilinc before doing the Java re-set.
