Tyler Electric Posted February 23, 2008 Share Posted February 23, 2008 I can no longer get the elk console to come up wheyn trying to access on the ISY admin console. this is running the beta 2.6.1. Is anyone else having a similiar problem Link to comment Share on other sites More sharing options...
Michel Kohanim Posted February 25, 2008 Share Posted February 25, 2008 Hello Tyler Electric, Have you tried resetting your ELK configuration? I have not been able to reproduce this problem. Please do keep us posted. With kind regards, Michel I can no longer get the elk console to come up wheyn trying to access on the ISY admin console. this is running the beta 2.6.1. Is anyone else having a similiar problem Link to comment Share on other sites More sharing options...
Tyler Electric Posted February 26, 2008 Author Share Posted February 26, 2008 Michel, How do I reset the elk config? the ip address and the port are correct now, is there something else i should do? ron Link to comment Share on other sites More sharing options...
Michel Kohanim Posted February 26, 2008 Share Posted February 26, 2008 Hello Ron, If they are correct, simply remove them both just to reset the network connections. Then reenter and save them; if the console still does not show up then I would suspect that M1XEP is either not on the network or is on a different IP address. With kind regards, Michel Michel, How do I reset the elk config? the ip address and the port are correct now, is there something else i should do? ron Link to comment Share on other sites More sharing options...
