Mobilinc and my ISY-99
I know people have been over this but I can't find a good easy link to follow.....I had a power outage and I cannot use my Mobilinc Iphone app over cellular communications. I have my router internal and external port set to 443. My ISY http port is set to 80 and https port set to 443. My mobilinc local port is set to 80. Any help is appreciated and if you have any questions please let me know and I will try to anwser them. Thanks again
Hello osurh18,
The first thing I suggest is to go to http://whatismyip.com and make sure your IP address has not changed.
Also, did you manually configure your router for remote access or did you use File | Enable Internet Access. If the latter, then you will need to redo it.
