Insteon Scene not working as ISY reports
WGKirby
The Insteon Engine indicates whether the device is an I1. I2 or I2CS device. I2CS is the latest Insteon protocol enhancement which requires ISY firmware that has been updated to support the protocol.
The Request Failed is an indication of powerline communications problems. The Query Insteon Engine would not normally have any external result. It insures the ISY has the correct Insteon Engine information.
It may be the communications problems are introducing unexpected results where I2CS is concerned. There are many users with I2CS devices that are not having the issues you are seeing.
In an earlier post I suggested deleting one of the I2CS devices, doing a factory reset and adding it back with the Event Viewer running at Level 3. I still think that is a good idea. The device responses for an I2CS device are well understood so a an event trace at Level 3 of the device add should provide good diagnostic information.
I will re-link some of my problems switches and capture the level 3 event entries later tonight. I do have an interesting list of switch models by good or bad link tables. Bad means when I do a diagnostic - show device link table I get incremental hex numbers and no valid entrees. Except for 1 older appliance linc, none of my switchlinc switches have good link tables. Maybe someone can see a pattern here that will help.
2476s bad
2477s bad
2486d bad
2486d bad
2477s bad
2477s bad
2476s bad
b2457d2 bad
2476s bad
2476s bad
2456s3 good
2477d good
2477d good
2476d good
2477d good
2477d good
2486d good
2477d good
2477d good
2477d good
Except for two 2486d devices which I cannot explain, the others are Relay devices which have been shipping with I2CS firmware. SmartLabs started with the Relay types and some others (like thermostats) for update to the I2CS protocol. The Dimmer types have been trailing the conversion process.
Take a look at page 1 of this topic. It was easy to identify I2CS devices back in April because many folks were not yet on an ISY level that had I2CS support. Now just about everyone is on an ISY level that supports I2CS so as new device types are being released by SmartLabs they go unnoticed. Eventually the Dimmer types will be switched to I2CS which may explain the 2486D.
viewtopic.php?f=30&t=8434&hilit=partial+list+i2cs
First of all I must apologize for this insanely long post.
I tried a number of things tonight with no success.
1. I ran an extension cord from another circuit to the PLM to try to rule out line noise.
I factory reset a switchlinc relay switch and linked it to the ISY using the automatic messaging option. I then ran diagnostics – show device links – and had incremental hex numbers in the listing (junk).
2. I installed my old 2412s PLM (works fine just not dual band) and re-ran the above test with the same results
3. I ran the above test steps and used advance option “Device reported messaging†option and had the same results.
4. I manually linked the switch link relay switch using the “New Insteon Device†and picked the 2476s switch and had the same results.
I then ran the test in step 1 and captured a level 3 event log of the process. I am not skilled enough to recognize any problems in this capture, but I hope one of the learned people of this forum can see something useful.
Thu 10/11/2012 10:55:03 PM : [LNK-BGN ] 02 64 01 00 06
Thu 10/11/2012 10:55:23 PM : [LNK-STAT ] 02 53 M(01) gid=00 1B.E1.15 021C 41
Thu 10/11/2012 10:55:23 PM : Linked: Linked 1B.E1.15.00 type=02.1C.41
Thu 10/11/2012 10:55:23 PM : [1B E1 15 1 ] Start : Adding device to ISY
Thu 10/11/2012 10:55:24 PM : [1B E1 15 1 ] Finish : Adding device to ISY was Successful
Thu 10/11/2012 10:55:24 PM : [All ] Writing 0 bytes to devices
Thu 10/11/2012 10:55:24 PM : [LNK-BGN ] 02 64 01 00 06
Thu 10/11/2012 10:55:46 PM : ---- Initializing the linked devices ----
Thu 10/11/2012 10:55:46 PM : [ 1B E1 15 1] Writing High Water Mark at Link 0
Thu 10/11/2012 10:55:46 PM : [LNK-END ] 02 65 06 : : Unexpected, ignored (65)
Thu 10/11/2012 10:55:46 PM : [1B E1 15 1 ] Using engine version i1 for '1B.E1.15.1'
Thu 10/11/2012 10:55:46 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:55:47 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:55:47 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:55:47 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F8 06 PEEK (F8)
Thu 10/11/2012 10:55:47 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F8 PEEK (F8)
Thu 10/11/2012 10:55:47 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:55:48 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:55:48 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:55:48 PM : [1B E1 15 1 ] Link 0 : 0FF8 [A2001CFC58FF1F01] Saving [A2001CFC58FF1F01]
Thu 10/11/2012 10:55:48 PM : [1B E1 15 1 ] Link 1 : 0FF0 [E2011CFC58FF1F01] Saving [E2011CFC58FF1F01]
Thu 10/11/2012 10:55:48 PM : [1B E1 15 1 ] Using engine version i1 for '1B.E1.15.1'
Thu 10/11/2012 10:55:48 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 00 06 SET-MSB(00)
Thu 10/11/2012 10:55:48 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 00 SET-MSB(00)
Thu 10/11/2012 10:55:48 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 32 06 PEEK (32)
Thu 10/11/2012 10:55:49 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 32 PEEK (32)
Thu 10/11/2012 10:55:49 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:55:49 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 00 06 SET-MSB(00)
Thu 10/11/2012 10:55:49 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 00 SET-MSB(00)
Thu 10/11/2012 10:55:49 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 21 06 PEEK (21)
Thu 10/11/2012 10:55:50 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 21 PEEK (21)
Thu 10/11/2012 10:55:50 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:55:50 PM : [FileOpen ] Open failed for [/LOG/A.LOG] (a)
Thu 10/11/2012 10:55:50 PM : ---- All Linked Devices are now initialized ----
Thu 10/11/2012 10:55:50 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 19 00 06 LTSREQ (LIGHT)
Thu 10/11/2012 10:55:51 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 02 FF (FF)
Thu 10/11/2012 10:55:51 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:55:51 PM : ---- Initializing the linked devices ----
Thu 10/11/2012 10:55:51 PM : ---- All Linked Devices are now initialized ----
Thu 10/11/2012 10:55:51 PM : [ 1B E1 15 1] OL 50
Thu 10/11/2012 10:55:51 PM : [ 1B E1 15 1] RR 33
Thu 10/11/2012 10:55:51 PM : [ 1B E1 15 1] ST 255
Thu 10/11/2012 10:55:51 PM : [All ] Writing 16 bytes to devices
Thu 10/11/2012 10:55:51 PM : [1B E1 15 1 ] Using engine version i1 for '1B.E1.15.1'
Thu 10/11/2012 10:55:51 PM : [1B E1 15 1 ] Link 2 : 0FE8 [0000000000000000] Writing [00..............]
Thu 10/11/2012 10:55:51 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:55:51 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:55:51 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B E8 06 PEEK (E8)
Thu 10/11/2012 10:55:52 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B E8 PEEK (E8)
Thu 10/11/2012 10:55:52 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:55:52 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:55:52 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:55:52 PM : [1B E1 15 1 ] Link 3 : 0FE0 : Writing High Water Byte
Thu 10/11/2012 10:55:52 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:55:53 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:55:53 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:55:53 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B E0 06 PEEK (E0)
Thu 10/11/2012 10:55:53 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B E0 PEEK (E0)
Thu 10/11/2012 10:55:53 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:55:54 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:55:54 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:55:54 PM : [1B E1 15 1 ] Link 4 : 0FD8 : Writing High Water Byte
Thu 10/11/2012 10:55:54 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:55:54 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:55:54 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B D8 06 PEEK (D8)
Thu 10/11/2012 10:55:55 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B D8 PEEK (D8)
Thu 10/11/2012 10:55:55 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:55:55 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:55:55 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:55:55 PM : [1B E1 15 1 ] Link 5 : 0FD0 : Writing High Water Byte
Thu 10/11/2012 10:55:56 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:55:56 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:55:56 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:55:56 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B D0 06 PEEK (D0)
Thu 10/11/2012 10:55:58 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B D0 PEEK (D0)
Thu 10/11/2012 10:55:58 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:55:58 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:55:58 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:55:58 PM : [1B E1 15 1 ] Link 6 : 0FC8 : Writing High Water Byte
Thu 10/11/2012 10:55:58 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:55:59 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:55:59 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:55:59 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B C8 06 PEEK (C8)
Thu 10/11/2012 10:55:59 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B C8 PEEK (C8)
Thu 10/11/2012 10:55:59 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:00 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:00 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:00 PM : [1B E1 15 1 ] Link 7 : 0FC0 : Writing High Water Byte
Thu 10/11/2012 10:56:00 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:00 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:00 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B C0 06 PEEK (C0)
Thu 10/11/2012 10:56:01 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B C0 PEEK (C0)
Thu 10/11/2012 10:56:01 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:01 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:02 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:02 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:02 PM : [1B E1 15 1 ] Link 8 : 0FB8 : Writing High Water Byte
Thu 10/11/2012 10:56:02 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:02 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:02 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B B8 06 PEEK (B8)
Thu 10/11/2012 10:56:02 PM : [iNST-SRX ] 02 50 23.71.15 1C.FC.58 23 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:02 PM : [standard-Direct Ack][23.71.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Thu 10/11/2012 10:56:02 PM : [iNST-SRX ] 02 50 23.71.15 1C.FC.58 23 28 0F SET-MSB(0F): Process Message: Ignored
Thu 10/11/2012 10:56:02 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 23 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:02 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Thu 10/11/2012 10:56:03 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B B8 PEEK (B8)
Thu 10/11/2012 10:56:03 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:03 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:04 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:04 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:04 PM : [1B E1 15 1 ] Link 9 : 0FB0 : Writing High Water Byte
Thu 10/11/2012 10:56:04 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:04 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:04 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B B0 06 PEEK (B0)
Thu 10/11/2012 10:56:05 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B B0 PEEK (B0)
Thu 10/11/2012 10:56:05 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:05 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:06 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:06 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:06 PM : [1B E1 15 1 ] Link 10 : 0FA8 : Writing High Water Byte
Thu 10/11/2012 10:56:06 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:07 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:07 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:07 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B A8 06 PEEK (A8)
Thu 10/11/2012 10:56:07 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B A8 PEEK (A8)
Thu 10/11/2012 10:56:08 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:08 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:08 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:08 PM : [1B E1 15 1 ] Link 11 : 0FA0 : Writing High Water Byte
Thu 10/11/2012 10:56:08 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:08 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:09 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B A0 06 PEEK (A0)
Thu 10/11/2012 10:56:09 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B A0 PEEK (A0)
Thu 10/11/2012 10:56:09 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:09 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:09 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:09 PM : [1B E1 15 1 ] Link 12 : 0F98 : Writing High Water Byte
Thu 10/11/2012 10:56:10 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:10 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:10 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:10 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 98 06 PEEK (98)
Thu 10/11/2012 10:56:11 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 98 PEEK (98)
Thu 10/11/2012 10:56:11 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:11 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:12 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:12 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:12 PM : [1B E1 15 1 ] Link 13 : 0F90 : Writing High Water Byte
Thu 10/11/2012 10:56:12 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:12 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:12 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 90 06 PEEK (90)
Thu 10/11/2012 10:56:13 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 90 PEEK (90)
Thu 10/11/2012 10:56:13 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:13 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:13 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:13 PM : [1B E1 15 1 ] Link 14 : 0F88 : Writing High Water Byte
Thu 10/11/2012 10:56:13 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:14 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:14 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:14 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 88 06 PEEK (88)
Thu 10/11/2012 10:56:14 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 88 PEEK (88)
Thu 10/11/2012 10:56:14 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:15 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:15 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:15 PM : [1B E1 15 1 ] Link 15 : 0F80 : Writing High Water Byte
Thu 10/11/2012 10:56:15 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:15 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:15 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 80 06 PEEK (80)
Thu 10/11/2012 10:56:16 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 80 PEEK (80)
Thu 10/11/2012 10:56:16 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:16 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:17 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:17 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:17 PM : [1B E1 15 1 ] Link 16 : 0F78 : Writing High Water Byte
Thu 10/11/2012 10:56:17 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:17 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:17 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 78 06 PEEK (78)
Thu 10/11/2012 10:56:18 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 78 PEEK (78)
Thu 10/11/2012 10:56:18 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:18 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:18 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:18 PM : [1B E1 15 1 ] Link 17 : 0F70 : Writing High Water Byte
Thu 10/11/2012 10:56:18 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:19 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:19 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:19 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 70 06 PEEK (70)
Thu 10/11/2012 10:56:19 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 70 PEEK (70)
Thu 10/11/2012 10:56:19 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:20 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:20 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:20 PM : [1B E1 15 1 ] Link 18 : 0F68 : Writing High Water Byte
Thu 10/11/2012 10:56:20 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:21 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:21 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:21 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 68 06 PEEK (68)
Thu 10/11/2012 10:56:22 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 68 PEEK (68)
Thu 10/11/2012 10:56:22 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:22 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:22 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:22 PM : [1B E1 15 1 ] Link 19 : 0F60 : Writing High Water Byte
Thu 10/11/2012 10:56:22 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:23 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:23 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:23 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 60 06 PEEK (60)
Thu 10/11/2012 10:56:23 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 60 PEEK (60)
Thu 10/11/2012 10:56:23 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:25 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:25 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:25 PM : [1B E1 15 1 ] Link 20 : 0F58 : Writing High Water Byte
Thu 10/11/2012 10:56:25 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:25 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:25 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 58 06 PEEK (58)
Thu 10/11/2012 10:56:26 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 58 PEEK (58)
Thu 10/11/2012 10:56:26 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:26 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:27 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:27 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:27 PM : [1B E1 15 1 ] Link 21 : 0F50 : Writing High Water Byte
Thu 10/11/2012 10:56:27 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:27 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:27 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 50 06 PEEK (50)
Thu 10/11/2012 10:56:28 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 50 PEEK (50)
Thu 10/11/2012 10:56:28 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:28 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:29 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:29 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:29 PM : [1B E1 15 1 ] Link 22 : 0F48 : Writing High Water Byte
Thu 10/11/2012 10:56:29 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:29 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:29 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 48 06 PEEK (48)
Thu 10/11/2012 10:56:30 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 48 PEEK (48)
Thu 10/11/2012 10:56:30 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:30 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:30 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:30 PM : [1B E1 15 1 ] Link 23 : 0F40 : Writing High Water Byte
Thu 10/11/2012 10:56:30 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:32 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:32 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:32 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 40 06 PEEK (40)
Thu 10/11/2012 10:56:32 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 40 PEEK (40)
Thu 10/11/2012 10:56:32 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:32 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:32 PM : [1B E1 15 1 ] Link 24 : 0F38 : Writing High Water Byte
Thu 10/11/2012 10:56:33 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:33 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:33 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:33 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 38 06 PEEK (38)
Thu 10/11/2012 10:56:34 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 38 PEEK (38)
Thu 10/11/2012 10:56:34 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:34 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:34 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:34 PM : [1B E1 15 1 ] Link 25 : 0F30 : Writing High Water Byte
Thu 10/11/2012 10:56:34 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:35 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:35 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:35 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 30 06 PEEK (30)
Thu 10/11/2012 10:56:35 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 30 PEEK (30)
Thu 10/11/2012 10:56:35 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:36 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:36 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:36 PM : [1B E1 15 1 ] Link 26 : 0F28 : Writing High Water Byte
Thu 10/11/2012 10:56:36 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:36 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:37 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 28 06 PEEK (28)
Thu 10/11/2012 10:56:37 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 28 PEEK (28)
Thu 10/11/2012 10:56:37 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:37 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:37 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:37 PM : [1B E1 15 1 ] Link 27 : 0F20 : Writing High Water Byte
Thu 10/11/2012 10:56:38 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:38 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:38 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:38 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 20 06 PEEK (20)
Thu 10/11/2012 10:56:39 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 20 PEEK (20)
Thu 10/11/2012 10:56:39 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:39 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:39 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:39 PM : [1B E1 15 1 ] Link 28 : 0F18 : Writing High Water Byte
Thu 10/11/2012 10:56:39 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:40 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:40 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:40 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 18 06 PEEK (18)
Thu 10/11/2012 10:56:40 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 18 PEEK (18)
Thu 10/11/2012 10:56:41 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:41 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:41 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:41 PM : [1B E1 15 1 ] Link 29 : 0F10 : Writing High Water Byte
Thu 10/11/2012 10:56:41 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:41 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:42 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 10 06 PEEK (10)
Thu 10/11/2012 10:56:42 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 10 PEEK (10)
Thu 10/11/2012 10:56:42 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:42 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:43 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:43 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:43 PM : [1B E1 15 1 ] Link 30 : 0F08 : Writing High Water Byte
Thu 10/11/2012 10:56:43 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:43 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:43 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 08 06 PEEK (08)
Thu 10/11/2012 10:56:44 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 08 PEEK (08)
Thu 10/11/2012 10:56:44 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:44 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:45 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:45 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:45 PM : [1B E1 15 1 ] Link 31 : 0F00 : Writing High Water Byte
Thu 10/11/2012 10:56:45 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:45 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:45 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 00 06 PEEK (00)
Thu 10/11/2012 10:56:46 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 00 PEEK (00)
Thu 10/11/2012 10:56:46 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:46 PM : [1B E1 15 1 ] Using engine version i1 for '1B.E1.15.1'
Thu 10/11/2012 10:56:46 PM : [1B E1 15 1 ] Link 0 : 0FF8 [A2001CFC58FF1F01] Writing [A2001CFC58FF1F01]
Thu 10/11/2012 10:56:46 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:46 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:46 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F8 06 PEEK (F8)
Thu 10/11/2012 10:56:47 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F8 PEEK (F8)
Thu 10/11/2012 10:56:47 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:47 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 A2 06 POKE (A2)
Thu 10/11/2012 10:56:48 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 A2 POKE (A2)
Thu 10/11/2012 10:56:48 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:48 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F9 06 PEEK (F9)
Thu 10/11/2012 10:56:48 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F9 PEEK (F9)
Thu 10/11/2012 10:56:48 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00)
Thu 10/11/2012 10:56:49 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00)
Thu 10/11/2012 10:56:49 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:49 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B FA 06 PEEK (FA)
Thu 10/11/2012 10:56:49 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B FA PEEK (FA)
Thu 10/11/2012 10:56:49 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 1C 06 POKE (1C)
Thu 10/11/2012 10:56:50 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 1C POKE (1C)
Thu 10/11/2012 10:56:50 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:50 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B FB 06 PEEK (FB)
Thu 10/11/2012 10:56:51 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B FB PEEK (FB)
Thu 10/11/2012 10:56:51 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:51 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 FC 06 POKE (FC)
Thu 10/11/2012 10:56:51 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 FC POKE (FC)
Thu 10/11/2012 10:56:51 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B FC 06 PEEK (FC)
Thu 10/11/2012 10:56:52 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B FC PEEK (FC)
Thu 10/11/2012 10:56:52 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:52 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 58 06 POKE (58)
Thu 10/11/2012 10:56:52 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 58 POKE (58)
Thu 10/11/2012 10:56:52 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B FD 06 PEEK (FD)
Thu 10/11/2012 10:56:53 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B FD PEEK (FD)
Thu 10/11/2012 10:56:53 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:53 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 FF 06 POKE (FF)
Thu 10/11/2012 10:56:53 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 FF POKE (FF)
Thu 10/11/2012 10:56:53 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B FE 06 PEEK (FE)
Thu 10/11/2012 10:56:54 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B FE PEEK (FE)
Thu 10/11/2012 10:56:54 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:54 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 1F 06 POKE (1F)
Thu 10/11/2012 10:56:55 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 1F POKE (1F)
Thu 10/11/2012 10:56:55 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:55 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B FF 06 PEEK (FF)
Thu 10/11/2012 10:56:56 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B FF PEEK (FF)
Thu 10/11/2012 10:56:56 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:56 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 01 06 POKE (01)
Thu 10/11/2012 10:56:56 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 01 POKE (01)
Thu 10/11/2012 10:56:56 PM : [MNG-LNK-RSP ] 02 6F 40 E2 00 1B E1 15 02 1C 41 06
Thu 10/11/2012 10:56:56 PM : [PLM ] Group 0 : Writing Controller Link matching [1B E1 15 1 ] Link 0 : FF8 [A2001CFC58FF1F01]
Thu 10/11/2012 10:56:56 PM : [1B E1 15 1 ] Using engine version i1 for '1B.E1.15.1'
Thu 10/11/2012 10:56:56 PM : [1B E1 15 1 ] Link 1 : 0FF0 [E2011CFC58FF1F01] Writing [E2011CFC58FF1F01]
Thu 10/11/2012 10:56:57 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F)
Thu 10/11/2012 10:56:57 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F)
Thu 10/11/2012 10:56:57 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:57 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F0 06 PEEK (F0)
Thu 10/11/2012 10:56:58 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F0 PEEK (F0)
Thu 10/11/2012 10:56:58 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:58 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 E2 06 POKE (E2)
Thu 10/11/2012 10:56:58 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 E2 POKE (E2)
Thu 10/11/2012 10:56:58 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F1 06 PEEK (F1)
Thu 10/11/2012 10:56:59 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F1 PEEK (F1)
Thu 10/11/2012 10:56:59 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:56:59 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 01 06 POKE (01)
Thu 10/11/2012 10:57:00 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 01 POKE (01)
Thu 10/11/2012 10:57:00 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:57:00 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F2 06 PEEK (F2)
Thu 10/11/2012 10:57:00 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F2 PEEK (F2)
Thu 10/11/2012 10:57:00 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 1C 06 POKE (1C)
Thu 10/11/2012 10:57:00 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 1C POKE (1C)
Thu 10/11/2012 10:57:01 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F3 06 PEEK (F3)
Thu 10/11/2012 10:57:01 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F3 PEEK (F3)
Thu 10/11/2012 10:57:01 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:57:01 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 FC 06 POKE (FC)
Thu 10/11/2012 10:57:01 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 FC POKE (FC)
Thu 10/11/2012 10:57:02 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F4 06 PEEK (F4)
Thu 10/11/2012 10:57:02 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F4 PEEK (F4)
Thu 10/11/2012 10:57:02 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:57:02 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 58 06 POKE (58)
Thu 10/11/2012 10:57:02 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 58 POKE (58)
Thu 10/11/2012 10:57:03 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 23 29 58 POKE (58)
Thu 10/11/2012 10:57:03 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Thu 10/11/2012 10:57:03 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F5 06 PEEK (F5)
Thu 10/11/2012 10:57:03 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F5 PEEK (F5)
Thu 10/11/2012 10:57:03 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:57:03 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 FF 06 POKE (FF)
Thu 10/11/2012 10:57:03 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 FF POKE (FF)
Thu 10/11/2012 10:57:04 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 23 29 FF POKE (FF)
Thu 10/11/2012 10:57:04 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Thu 10/11/2012 10:57:04 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F6 06 PEEK (F6)
Thu 10/11/2012 10:57:04 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F6 PEEK (F6)
Thu 10/11/2012 10:57:04 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:57:04 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 1F 06 POKE (1F)
Thu 10/11/2012 10:57:05 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 1F POKE (1F)
Thu 10/11/2012 10:57:05 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:57:05 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F7 06 PEEK (F7)
Thu 10/11/2012 10:57:06 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F7 PEEK (F7)
Thu 10/11/2012 10:57:06 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 10/11/2012 10:57:06 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 01 06 POKE (01)
Thu 10/11/2012 10:57:06 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 01 POKE (01)
Thu 10/11/2012 10:57:06 PM : [MNG-LNK-RSP ] 02 6F 41 A2 01 1B E1 15 02 1C 41 15
Thu 10/11/2012 10:57:06 PM : [PLM ] Group 1 : Writing Responder Link matching [1B E1 15 1 ] Link 1 : 0FF0 E2011CFC58FF1F01]
Thu 10/11/2012 10:57:06 PM : [All ] Writing 0 bytes to devices
Thanks for the last trace. It is of a Start Linking sequence that did not check for the Insteon Engine so it does not know it is an I2CS device. All the Peek/Poke commands fail to function because the I2CS firmware does not contain Peek/Poke. I don't know what UI (Admin Console) is being used but it is not 3.2.6.
I don’t see how Help | About can be displaying Firmware and UI as 3.2.6.
Hello everyone,
Was this ISY recently upgraded to 3.2.6 and especially via auto upgrade? If so, it's possible that in Help | About you will see 3.2.6 even though the firmware is not 3.2.6.
This can only happen if you upgraded from a previous release to 3.2.6. This is NOT the case if this is a new ISY that came with 3.2.6.
The best test would be to:
1. Telnet to ISY
2. Login, and at the prompt, type:
VE
I think we have an answer. I did upgrade the ISY through the push update process and the screen did report all was well and running at 3.2.6 for both interface and firmware, but Michel was right, when I telneted int the box I recieved the following:
Product: (1050) ISY 99i 1024 IR
App: Insteon_UD99
Platform: ISY-C-99
Version: 3.1.17
Build Date: 2012-01-19-15:34:02
Other Services:
- Programs Enabled
- IR Enabled
Modules:
21040 - Networking Module
Since this version does not have i2cs support I think the problem has been identified. The question now is what is the best way to fix this. Should I download a beta and upgrade out of this issue or should I download 3.2.6 and re-apply. Your ideas would be appreciated.
