ELK Outputs and ISY with or without Module
hkmail1
Based on a few posts here, I was trying to send emails from ISY 99 based on Elk M1G outputs using elk rules to turn on the output. My problem is I can't see the elk outputs from the program tab in the ISY. I just upgraded to newest firmware on isy and elk. Everything else works. The elk can turn on insteon lights and I can see the elk status from the isy.
Do I need the elk module to do this? If I don't then anyone have any ideas why I can't see the outputs? I logged into Elk and selected show for the outputs and then logged out, but haven't found anything else to try.
If I do need Elk Module, I don't see where on the Universal Devices website how to buy it.
Kevin
  • 1 month later...
If you have the ELK module...
Initially, only outputs above 65 show up.
  • [*:2iuttivs]You also have to go into ELK RP
    • [*:2iuttivs]Under the 'Automation' folder
      • [*:2iuttivs] go to the Outputs item and
        • [*:2iuttivs]tick the outputs you want to show.
Initially, for me in ELKRP, none of the Outputs lower than 65 where selected.
As soon as I ticked them,
went back to my ISY Admin / Configurtation / Elk / refresh topology
they showed up as usable items in programs.
Now I have 8 FormC contacts (on an ELK-M1RB) to play with from my ISY!
tom
  • [*:6iky65dk]You also have to go into ELK RP
    • [*:6iky65dk]Under the 'Automation' folder
      • [*:6iky65dk] go to the Outputs item and
        • [*:6iky65dk]tick the outputs you want to show.
tom
I have 208 Elk outputs showing up in ISY (which I think is Elk's max?)
  • [*:3a43ikuq]You also have to go into ELK RP
    • [*:3a43ikuq]Under the 'Automation' folder
      • [*:3a43ikuq] go to the Outputs item and
        • [*:3a43ikuq]tick the outputs you want to show.
tom
Me too, but I only have the bottom ones populated (on the ELK) with any output relays via an M1RB.
