Has the link to the Admin tool disappeared?
I've tried running the Admin tool from the link indicated as the best way to access it (http://www.universal-devices.com/99i/3.3.7/admin.jnlp) and I am getting a 'page not found' error. Tried turning off my firewall and still got the error. I assume the problem is on my side, but on the off chance that it's at your end I thought I would post this.
Any idea what is causing the problem?
No probably not your side.
Web site has a problem.
That link is not working at the moment.
I get the same error for the dashboard also.
If you use its IP address from your web browser. You should be able to see it. Though you will get a automatic update failed message as its web address is also not working.
Yes, I am getting the 'update failed' message as well, although now I can get into the app itself.
Thanks for posting - I am also having intermittent wifi problems (unrelated) and not knowing about this was making the debugging a little harder.
