Posted January 28, 201312 yr Anyone have advice on what they use as a loud siren. I don't have an alarm system, but I'd like to trigger a few Insteon-controlled sirens around the house. My first thought was to find a simple loud horn that plugs in to a outlet linc. That's been hard - it seems most alarm horns are low power...which I guess means going the whole I/O linc route? Any advice on best approach? Thanks
January 28, 201312 yr You could simply put the horn's power supply on an appliancelinc. Might be cheaper than the IOLonc route. If the horn are all to sound at the same time, you could wire them all to a single supply. -Xathros
