palayman
Everything posted by palayman
  1. Rebooted again. Didn't fix the problem for me.
  2. Me too! I checked the ISY portal and it was there but when I tried web access it said "error, Loading: /config/" Then I rebooted the ISY. It still is available in my local network, but it doesn't appear on the ISY portal. Paul
  3. Answer provided in another thread. It worked for me.
  4. Still offline as of 10:22 EST, so I guess it's not directly related to the Portal.
  5. Is this somehow related to the ISY Portal issue which now seems to be resolved? Paul
  6. I'm in an even more comical situation. Built a new house a few years ago just when Polisy was coming out. None were available so I bought an ISY. Then ISY stop supporting the latest version of nodeservers on a Raspberry Pi, so I bought a Polisy and installed some nodeservers (that would have run on the the RPi) with intention of moving the ISY to Polisy and updating the the new nodeserver version a short time later. Unfortunately a couple of the nodeservers I needed wern't yet ported so I never moved. Instead I started using Home Assistant on a Small PC and integrated with the ISY to get the functionality I wanted, with the intention of moving everything once the nodeservers were available. Well I never did move and found that only two of the five nodeservers were something I needed/used and one of the two I used went away - myQ. So I plan to move the one I use, envisalink, over to Home Assistant and turn off the Polisy. No point in moving to Eisy at this point. Besides it might be superseded before I have time to integrate. Is there a market for lightly used Polisy's?
  7. I also had a strange admin console problem. This fixed it.
  8. Thanks!!! It worked and the console loaded so much faster. You're a life saver. Paul
  9. firmware 5.3.4. Not sure where you find UI version.
  10. Already did this. Cleared cache and installed fresh Java. Also used used a fresh start.jlnp from the same link. Didn't work. Paul
  11. Hi, Have an ISY with no updates for several years. Tried to go in and edit a program. Console loaded, but every time I go to the programs tab it locks up showing a popup saying "loading scene widgets". Have rebooted the laptop, checked java version, and rebooted the isy to no avail. Any ideas? Paul
  12. Is there an ETA on the new solution? Unfortunate that you didn't warn us until June 6 and submit new code until a couple of days ago, even though the announcement was made by Google almost a year ago. We rely heavily on this interface. Paul
  13. Yea, it is cloud based.
  14. Filed a ticket and was guided to add a "hint" for the device to work correctly. You might want to file a ticket to get it working. '
  15. Get this error when I try to add a new device to Google Home Spokens. Any Idea why? HTTP error 400 : Device cannot be added to the spoken database
  16. Unfortunately I was one of them. I thought it would be wonderful. Open hardware (Raspberry Pi) and open source software. Beautiful. Then there was the short lived Policy, PG3 and node servers with no source and no tangible support commitments. My wife is severely disabled and has come to be dependent on home automation to give her some degree of independence. Unanticipated change is not desirable. Hence my diligence.
  17. As to your first question, I mean let us see the license terms before I even try it. Basically I trying to figure out if is worth while moving from my ISY and PG2 to the Polisy I have owned for almost 2 years and PG3 (which has already been replaced by the EISY) versus moving entirely to Home Assistant. Don't really want to invest in the move until I've assessed fully the costs and benefits for my particular situation. I think this is reasonable.
  18. Is this license available for review before you purchase or use the node server?
  19. Perhaps the developers should provide some statement of support expectations in the table so users could decide if it seems adequate for their needs. Then there is no expectation mismatch. Is it safe to assume source code for node servers in the production store is not provided? Somewhat concerned that a developer might get pulled away or disappear. Could there should be a mechanism for the source to be made available after some period of time if the this should happen.
  20. This is awesome! A few questions. Mainly for someone at UDI. Any thought of adding ratings and/or node server reviews to this table? What is the formal difference between production and non-production stores? Are there any guarantees that node servers in the production store will be supported for a reasonable period of time and changes to the third party API will be supported promptly? Just want to understand what I'm signing up for. Was not happy when I couldn't move to PG3 when a couple of node servers I was using weren't available during the transition from PG2. Currently running Home Assistant in parallel to gain access to these. Paul PS Love the Solution Tag UDI has added to threads!
  21. Outside of the actual PG3 Node Server store, is there a table of available node servers, support level and price? Considering finally moving from PG2 to PG3 versus other options. Thanks, Paul
  22. Use another Yolink valve to dump the pressure tank into a convenient location after you turn off the water to the house. I use one to dump water from the pool if rain over fills it.
  23. @Michel KohanimDidn't really expect one, but you might want to fix the landing page from the email that says you'll get one if you log in. Cheers, Paul
  24. Got notice that they were available in email. When I logged in to order it said some sort of discount was applicable if I logged in. Did that, but no discount. @Michel Kohanim Am I missing something? Best regards, Paul
